CHINTDTSU666 power meter data to RS485 TTL
HI
i am trying to integrate CHINT DTSU666 power meter with ESPhome. connection is ok when inverter is off(during night) when inverter turns on in the morning i start to get crc errors. what could be the problem. address is same on all three devices also baudrate is 9600.
esphome:
  friendly_name: CHINT DTSU666
esp32:
  board: esp32dev
  framework:
    type: arduino
# Enable logging
logger:
  level: verbose
  baud_rate: 0
# Enable Home Assistant API
api:
  encryption:
    key: ""
ota:
uart:
  tx_pin: 17
  rx_pin: 16
  baud_rate: 9600
  stop_bits: 1
  debug:
    direction: BOTH
    dummy_receiver: false
    after:
      delimiter: "\n"
    sequence:
      - lambda: UARTDebug::log_string(direction, bytes);
modbus:
  disable_crc: False
  send_wait_time: 250ms
modbus_controller:
  - id: powermeter1
    address: 1
    modbus_id: modbus1
    update_interval: 3s
    setup_priority: -10
############   NAPETOST   ####################
 - platform: modbus_controller
   modbus_controller_id: powermeter1
   name: "test Napetost Ua"
   address: 0X2006
   unit_of_measurement: "V" ## for any other unit the value is returned in minutes
   register_type: read
   device_class: "voltage"
   value_type: FP32
   accuracy_decimals: 2
   filters:
     - multiply: 0.1
wifi:
  networks:
   - ssid: !secret wifi_ssid
   - ssid: !secret wifi_1_ssid
     password: !secret wifi_1_password
   - ssid: !secret wifi_2_ssid
     password: !secret wifi_2_password
  ap:
    ssid: "Esphome-Web-237360"
    password: "irD1gqIIn1lo"
captive_portal:
Hi Simon,
please can you tell me how did you connect DTSU666 with ESP ?
DTSU666 hast 2 wire A,B . Esp has many PINs
did you join it directly? without level shifter (5V to 3.3V) ?
