Chip card : Not "toggle" but execute
Hi there,
I need to be able to switch my tablet screen on when someone rings the bell, independently of the correct screen state (OFF, or already switched on). I found the right entity to switch it on or off, but for the moment I test it with a chips card where only “toggle” is available :
type: custom:mushroom-chips-card
chips:
  - type: entity
    entity: switch.lenovo_tab_m10_plus_3rd_gen_screen
    tap_action:
      action: **toggle**
    use_entity_picture: false
At the end, I want the screen to be turned on when someone rings whatever the current state of the tablet screen is … so is there another possibility than “toggle”, otherwise the issue will be that if the screen is already switched ON, the toggle will switch it off when someone rings !
