If I was on your feet I want not expect to get it up and running in a short time. Probably Raspian has the installation that will fit for the new baby.
You’ll need to consider heat issues too particularly if you intend using a case. Passive cooling is a minimum requirement installed in a case. There has been a firmware introduced that will help with high cpu running temperature.
