BernieV
(Bernd Vantyghem)
December 15, 2021, 6:57pm
1
I have an automation with a choose condition and it always skip the conditions. This is the choose condition:
choose:
- conditions:
- condition: template
value_template: '{{ states("sensor.combi_koelkast_power") | int(0) < 2 }} '
sequence:
- service: input_select.select_option
option: Niet actief
entity_id: input_select.combi_koelkast_status
- conditions:
value_template: '{{ states("sensor.combi_koelkast_power") | int(0) > 35 }}'
sequence:
option: Koelen
default: []
With sensor
combi_koelkast_power:
state_class: measurement
unit_of_measurement: W
friendly_name: Combi koelkast
icon: mdi:fridge
device_class: power
Has anyone an idea why?
Thx
Bernd
Well reading the automation, the only obvious answer is that the wattage of the fridge is always above 2W, and always below 35W ? And thus neither condition matches.
If you look at the Automation trace, it will tell you what the actual values are.
What is the trigger for the automation?
BernieV
(Bernd Vantyghem)
December 15, 2021, 7:23pm
4
Ths is the trigger for the automation:
platform: template
value_template: '{{ states("sensor.combi_koelkast_power") | round(0) }}'
This value can be 0 to 50
That’s not really a trigger though? It doesn’t do anything, there is no logic in it.
You’d be better off just using a numeric_state trigger for the sensor, without an above or below.
123
(Taras)
December 15, 2021, 7:59pm
6
Use a State Trigger .
alias: example
- platform: state
entity_id: sensor.combi_koelkast_power
condition:
value_template: >
{% set p = trigger.to_state.state | int(0) %}
{{ p < 2 or p > 35 }}
option: "{{ 'Niet actief' if trigger.to_state.state | int(0) < 2 else 'Koelen' }}"
