Choose no action -> Error?
If I use the choose action and end up with no actions in my action block, will this generate an error / warning?
I currently have conditions in the condition block to prevent this, but wonder if it is necessary.
- alias: 'Get Deck Tone Level'
  - platform: state
    entity_id: sensor.deck_bass_level
  - platform: state
    entity_id: sensor.deck_treble_level
  condition:
  - condition: or ### Do I need this? ###
    conditions:
    - condition: template
      value_template: "{{ states('sensor.deck_bass_level') != states('input_number.deck_bass_level') }}"
      value_template: "{{ states('sensor.deck_treble_level') != states('input_number.deck_treble_level') }}"
    value_template: "{{ states('sensor.deck_bass_level') not in ['Unknown', 'None', 'Unavailable'] }}"
    value_template: "{{ states('sensor.deck_treble_level') not in ['Unknown', 'None', 'Unavailable'] }}"
  - choose:
    - conditions:
      sequence:
      - service: input_number.set_value
          entity_id: input_number.deck_bass_level
          value: "{{ states('sensor.deck_bass_level')|float }}"
  - choose:
    - conditions:
      sequence:
          entity_id: input_number.deck_treble_level
          value: "{{ states('sensor.deck_treble_level')|float }}"
99% sure nothing happens and no errors. It’s like an if statement without an else. The only thing this would guard against is populating the last_triggered.
Also, if you’re using templates it would probably be better if you put them in 1 templaet:
      value_template: >
        {% set bass = states('sensor.deck_bass_level') %}
        {% set treble = states('sensor.deck_treble_level') %}
        {% set user_bass = states('input_number.deck_bass_level') %}
        {% set user_treble = states('input_number.deck_treble_level') %}
        {% set unknown = ['Unknown', 'None', 'Unavailable'] %}
        {{ (bass != user_bass or treble != user_treble)
            and bass not in unknown
            and treble not in unknown }}
So send one template to the sandbox for evaluation rather that doing it piecemeal.
Always done it that way but never actually thought about it.
Good rule of thumb
:+1:
