1mfaasj
(Bowa)
January 18, 2024, 8:56pm
1
Hi
Is it possible that my automation, calling this service, selects a random mp3 from the chime path? There are some MP3 files there and I want an MP3 to be randomly selected and played.
service: chime_tts.say
chime_path: /media/sounds/test1.mp3
tts_platform: tts.google_nl_com
volume_level: 1
message: test message
device_id: 66d5d1269b164cd50d3e6343354652410
Is the only possible way to use a template line like this?
option: "{{['testmp1','testmp2', 'testmp3']|random}}"
but then I need to define all MP3 file names, what I would like to avoid. (there are a lot).
(Taras)
January 18, 2024, 9:21pm
2
Create a Folder Sensor using the Folder integration .
The sensor will have a file_list
attribute containing a list of all files it found (as per how you configured the Folder Sensor).
Assuming the Folder Sensor is sensor.my_music
, your template will look something like this:
chime_path: "{{ state_attr('sensor.my_music', 'file_list') | random }}"
NOTE
Ensure you follow the integration’s instructions. The usual problem is that the Folder Sensor doesn’t have permission to access the desired folder.
VDRainer
January 19, 2024, 10:23am
3
The disadvantage of the folder sensor is that it ignores sub folders.
If you have a folder structure like
➜ ~ tree /media/sounds
/media/sounds
├── file with space.mp3
├── file1.mp3
├── file2.mp3
└── subfolder
├── file1.mp3
└── file2.mp3
the files in the subfolder are not visible.
filter: "*"
number_of_files: 4
bytes: 0
file_list:
- /media/sounds/file1.mp3
- /media/sounds/file with space.mp3
- /media/sounds/subfolder <---
- /media/sounds/file2.mp3
unit_of_measurement: MB
device_class: data_size
icon: mdi:folder
friendly_name: sounds
So my approach is:
Create a little bash script
#!/bin/bash
MP3DIR='/media/sounds'
MP3PATH=`find $MP3DIR -type f -name '*.mp3' | shuf -n 1`
MP3=`basename $MP3PATH`
echo "{\"mp3\": \"$MP3\", \"mp3path\": \"$MP3PATH\"}"
make it executable
chmod +x /path/to/script.sh
now a command_line sensor
command_line:
- sensor:
command: "/path/to/script.sh"
value_template: "{{ value_json.mp3 }}"
json_attributes:
- mp3path
Now you can use the mp3path
attribute of the command_line sensor
chime_path: "{{ state_attr('sensor.random_mp3', 'mp3path') }}"
1mfaasj
(Bowa)
January 19, 2024, 10:45am
4
Thanks for this addition for files in subfolders!
ajueket
(oron_enthusiast)
December 27, 2024, 6:36am
5
Hello, I am having a tough time with folder/media id paths here.
This is what my code looks like:
action: media_player.play_media
metadata: {}
media_content_id: {{state_attr(‘sensor.wow’, ‘file_list’) | random }}
media_content_type: audio/mpeg
entity_id: media_player.nesthubmax23e0
123
(Taras)
December 27, 2024, 1:51pm
6
Add outer double-quotes to the template.
media_content_id: "{{state_attr('sensor.wow', 'file_list') | random }}"
ajueket
(oron_enthusiast)
December 27, 2024, 3:57pm
7
I tried this and it didn’t seem to work.
When I try to play from the template, the content id path is:
metadata: {}
media_content_id: "/media/Wow/58_WeWow_on_the_Weekend_(9-28-24).mp3"
When I play media directly, content id path is: (This works fine btw)
media_content_id: >-
media-source://media_source/local/Wow/04_WeWow_The_Great_Indoors_2024_-_Day_5:_Into_the_Outdoors_(12-20-24).mp3
My “wow” folder is in my media folder
123
(Taras)
December 27, 2024, 4:03pm
8
Go to Developer Tools → Templates, erase anything that might already be there, then enter this template:
{{ state_attr('sensor.wow', 'file_list') | random }}
What does it report?
ajueket
(oron_enthusiast)
December 27, 2024, 4:04pm
9
It reports
/media/Wow/06_WeWow_The_Great_Indoors_2024_-_Day_3:_Bored_Games_(12-18-24).mp3
123
(Taras)
December 27, 2024, 4:14pm
10
It would appear that Home Assistant doesn’t have access to that folder path.
In sensor.wow’s file_list attribute, rename all entries that look like this:
To simply this:
Then you can use this:
media-source://media_source/local/Wow/{{ state_attr('sensor.wow', 'file_list ') | random }}
ajueket
(oron_enthusiast)
December 27, 2024, 6:23pm
11
Thank you.
I tried this in config.yaml
#cleaned wow list
template:
- sensor:
- name: "Cleaned WOW File List"
state: >
{{ state_attr('sensor.wow', 'file_list') | map('replace', '/media/Wow/', '') | list }}
It works in Developer Tools → Templates but has no values under Developer Tools → States
I tried triggering the template by forcing sensor.wow to change and still nothing under attributes for sensor.cleaned_wow_file_list
Please let me know if you see anything I am doing wrong
123
(Taras)
December 27, 2024, 6:33pm
12
Did you try what I had suggested? Because the latest thing you posted isn’t what I suggested.
Or is it simply impossible to manually rename the items in the file_list attribute, so that’s why you composed another Template Sensor?
It implies you either overlooked to Reload Template integration after composing the Template Sensor or you did reload it but there’s an error in the configuration.
For example, if the cleaned wow list exceeds 255 characters it will not be displayed (an entity’s state
value is limited to 255 characters). In that case, you should store the cleaned wow list a new attribute (in the Template Sensor). Attributes allows for about 16K characters.
ajueket
(oron_enthusiast)
December 27, 2024, 7:19pm
13
It works!
Thank you for your help!
I didn’t want to manually use find/replace for the sensor.wow attribute hence the new template sensor.
Final solution:
In config.yaml
#folder Integration
- platform: folder
folder: /media/Wow
#cleaned wow list
template:
- sensor:
state: "Cleaned"
attributes:
cleaned_file_list: >
Action in automation:
metadata: {}
media-source://media_source/local/Wow/{{state_attr('sensor.cleaned_wow_file_list', 'cleaned_file_list') | random }}
entity_id: media_player.googlehome4260
123
(Taras)
December 27, 2024, 7:32pm
14
If you wish, you can avoid creating sensor.cleaned_wow_file_list
and simply use its template within media_content_id
media-source://media_source/local/Wow/{{ state_attr('sensor.wow', 'file_list') | map('replace', '/media/Wow/', '') | list | random }}
ajueket
(oron_enthusiast)
December 27, 2024, 8:15pm
15
Even better and cleaner. Thank you.
