Goal
I want to play music from my Navidrome server through several existing active speakers. Each speaker system would have an ESP32-based Wi-Fi audio endpoint connected to its 3.5 mm AUX input.
Home Assistant should provide playback and volume control. Synchronized multi-room playback is preferred, and I would eventually like to add Home Assistant voice control and announcements.
Current environment
- Home Assistant version: 2026.7.4
- Installation type: Container
- Music Assistant version: Not installed yet
- Navidrome version: 0.52.5
- Network: HA server on Ethernet and ESP32 devices on 2.4 GHz wireless
- Speakers: Various active speakers/soundbars
This is currently a planning question, so I don’t yet have failing YAML or logs to share.
Design under consideration
Navidrome
│ OpenSubsonic
Music Assistant
│ Wi-Fi
ESP32 audio endpoint
│ stereo line-level output
Active speaker AUX input
I have several ESP32-WROOM-32D boards, but they lack PSRAM, and I would need to buy separate DACs. Instead, I’m considering an integrated board such as the Sonocotta HiFi-ESP32 Plus, probably the ESP32-S3 version.
My leading firmware option is ESPHome with Sendspin. Squeezelite-ESP32 or Snapcast could be alternatives if they are more dependable.
Relevant documentation and projects I’ve found:
- Music Assistant Sendspin support
- ESPHome Sendspin media source
- Sonocotta ESP32 audio boards and firmware
- Squeezelite-ESP32
Sendspin appears closely integrated with Music Assistant and supports synchronization and delay adjustment, but it is still labeled a technical preview.
Questions
For anyone running ESP32 audio endpoints with Music Assistant:
- Is ESPHome with Sendspin reliable enough for everyday, long-running music playback?
- Would you choose the HiFi-ESP32 Plus S3, its classic ESP32 version, or another integrated board with stereo line output?
- Is Squeezelite-ESP32 currently a more dependable choice if synchronized playback is important?
- Have active speakers introduced enough internal latency to require per-player delay adjustment?
- Are Home Assistant announcements and returning to music afterward working reliably?
I plan to build and test one endpoint for my living room before purchasing several. I’d particularly appreciate first-hand experience with these hardware and firmware combinations.
