Choosing the right Thread Radio / Thread Border Router
Hi everyone,
I want to get started with Thread, so naturally, I am evaluating which is the best (most reliable?) option for a Thread Border Router. My tendency goes strongly into using my HAOS machine as an Open Thread Border Router, and thus I need a Thread radio. But, as I see it, there are mainly four options overall:
  1. OTBR on HAOS machine by using the official HA Connect ZBT-1 (formerly SkyConnect) radio. My expectation would be that this runs relatively stable and is a solid solution.
  2. OTBR on HAOS machine with a third-party radio (e.g., Smlight SLZB-06M). Those offer advanced features (bigger antennas, easier placing through PoE, etc.), but I wonder whether the firmware interacts nicely with HA and I fear lacking support.
  3. A third-party device that includes a Thread Border Router (e.g., something like an Apple Homepod, Alexa hardware, etc.). As I would purchase such a product just for the Thread Border Router functionality, I would not expect any real advantages, but feel free to prove me wrong.
  4. A dedicated third-party Thread Border Router (e.g., GL.iNet GL-S20), seems like a mixture of solutions 2 (but more independent) & solution 3 (but no unnecessary features).
All Thread devices to be used will be Matter-over-Thread. I do not plan to use ZigBee, Z-Wave, or any other wireless protocols (despite Wi-Fi, of course :wink: )
Thanks for your insights :slightly_smiling_face:
IMHO:
#1 is the setup I use. It works for me, but for others, it is very problematic with Thread dataset/credentials management, but if you are starting from scratch its more manageable.
#2 that particular device in PoE mode is not recommended by the HA Matter/Thread developers
#3 Apple/Google (not Alexa and maybe not others) would be the easiest
#4 I don’t have experience with.
I already had a few HomePods mini, so I just use them. The main perk is that they make commissioning easy with Apple Home, but like others (e.g. Google, Alexa) they hide the credentials so make it complex to use other apps (e.g. HA) for commissioning.
My parents needed to upgrade their WiFi so I got them Eero 6 mesh routers, which also have TBR built-in. Kudos to Eero for making the Thread credentials easy to pull from their management app to facilitate commissioning with the HA companion app. A good solution if you don’t already have WiFi 6 or better (which I highly recommend).
I considered the GL.iNet to better learn OTBR, but found it somewhat expensive. So instead I flashed a $5 esp32-h2 with RCP firmware, and setup OTBR docker container (an esp32-s3 also works). I find that it works fine for a cheap config, no “firmware interaction” issues with HA. But mixing TBR types/vendors is still a mess because of credential sharing/syncing issues so I only use it for testing.
Keep in mind that one TBR is adequate, and line-powered Thread devices will extend the reach of your mesh, compensating for antenna/range limitations.
Thanks for your insights! :slightly_smiling_face:
Hm, do you have more information where these recommendations can be found, @wmaker ?
Thats a good hint. I already have a powerful router that I do not want to replace. But it totally makes sense to combine WiFi and Thread routers.
Thanks for pointing that out, I did not have this in mind. I think serious everyday usage will be off the table for most users.
Yes, a full thread device (FTD) works as a repeater and makes the mesh more robust, but the TBR still is a single point of failure - or how does it work when you have multiple HomePods or the like (solution #3)?
If you click on the following link, you’ll see there is a warning that has been added regarding this.
And here is a Reddit topic about this from baloob
https://www.reddit.com/r/MatterProtocol/comments/1hl34i0/comment/m3js1kf/
Thanks again for your replies, @wmaker and @peterxian .
As a solution, it can be said that the “best” solution depends on the personal situation. Here would be my takeaways:
  • If you already have hardware in your system that servers as a TBR, you can just use this (solution #3). This is easily done and reliable.
  • Solution #1 is probably the best, if you have no existing hardware with TBR capability.
  • For solution #4, there is hardly any experience in the community.
    • @all: If you have something to add, please add your experiences!
    • Especially the combination of WiFi and Thread routers seems to be very interesting (to my knowledge, currently some Amazon Eero routers and the Google Nest Wifi Pro (Wi‑Fi 6E) support this).
  • Solution 2 is discouraged (at least for the specific device I mentioned, see reply by @wmaker).
    • There seems to be little usage of other devices similiar in the community. If you can report something, please add your thoughts!
I decided to use a ZBT-1 (solution #1). It’s definitively not a bad option, time will tell how happy I am. So far, I can’t report much - the setup was okay (I tried to rename the Thread network, but failed doing so; the rest was flawless), but I only have one Thread device so far. This works without issues. More devices will follow in the next months, I will post an update then.
Just a note on an old thread (no pun). Choose #1 if you like, but you really need more than one border router, and only one can run on the HA server.
You want at least a couple of border routers to have redundant paths and cover failures. But the second router can’t be the Home Assistant’s OTBR App and ZBT-1. Now, after you add this second router, there is not guarantee at all that the ZBT-2 will ever be used again. For all you know, your Thread network might design that your backup router should be primary. I don’t think there is any manual control over this.
In 2026, the least cost border router is a bare ESP32-C6 device flashed with router software and plugged into a low-power phone charger. You can have the #4 option now for about $6, assuming you already have a spare charger.
