Hi in the first floor i have a lot of motion and presence sensors.I want to make an automation that works if at least one sensor is in motion/presence status the christmas tree lights are on.if all the sensors doesnt have motion the light go off.I try different approaches in the ui but i cant make it work as I want.Any advice?
You could put all the sensors in a group and then just trigger off the group. Whatever state the group is in is the state your lights should be in.
That is a smart idea thanks.one more question.My other automations who has trigger one sensor will still work as usual?
Yes, since you are using different automations.
- The existing one will use single entities as a trigger
- Your Christmas automation will use a group of sensors as an entity to trigger
