if a little in advance, I would create an automation that works over the Christmas period. this automation should turn on 2 switches switch.plug_158d00010dd879 and switch.plug_158d00013e76ab, the automation should start from December 8th until January 8th and turn on at sunset and turn off at midnight. is an example possible with yaml or node red? thank you
You will need to change the triggers from lux to sunset/midnight and change the disable / enable dates. As well as the switch entity ids.
## Xmas Tree Light Automation
- id: xmas_lights_on
alias: 'Xmas Lights On'
platform: numeric_state
entity_id: sensor.outside_light_level
below: 660
service: switch.turn_on
entity_id: switch.xmas_tree_lights
- id: xmas_lights_off
alias: 'Xmas Lights Off'
- platform: time
at: '02:00:00'
- platform: state
entity_id: binary_sensor.dark_outside
to: 'off'
condition:
condition: state
entity_id: switch.xmas_tree_lights # only if the lights are on
state: 'on'
service: switch.turn_off
- id: xmas_lights_enable # enable xmas lights auto on/off automation on December 1st at midday.
alias: 'Xmas Lights enable'
initial_state: true
platform: time
at: '12:05:05'
condition:
condition: template
value_template: '{{ now().month == 12 and now().day == 1 }}'
- service: homeassistant.turn_on
entity_id: automation.xmas_lights_on
entity_id: automation.xmas_lights_off
- id: xmas_lights_disable # disable xmas lights auto on/off automation on January 6th at midday.
alias: 'Xmas Lights disable'
initial_state: true
platform: time
at: '12:00:05'
condition:
condition: template
value_template: '{{ now().month == 1 and now().day == 6 }}'
- service: homeassistant.turn_off
thank you. this is great
