Chrome and Configuraton panel on 0.51.2
So having a weird issue after upgrading to 0.51.2. In Chrome (version 60.0.3112.101) when I go to the configuration panel nothing will display until I hit refresh. When I do that I get the updated panel buttons but they do not look right as in missing the greater than sign. When I click on Configuration yaml all I have is a check config button and nothing else.
If I log in using Edge browser I see the buttons and everything functions and works like it is supposed to. Is anyone else seeing this? Is this a bug?
Chrome Version 60.0.3112.90 (Official Build) (64-bit)
Everything working fine. I’ll upgrade and see what happens.
Edit: Chrome Version 60.0.3112.101 (Official Build) (64-bit)
Still works fine.
Thanks for looking. Not sure what is going on. I’ll continue to dig and see what I come up with.
I am having the same issue. Running “Version 60.0.3112.101 (Official Build) (64-bit)” and the configuration page is blank.
So I shut down my box and didn’t touch it till the next day and the issue appears to have resolved itself. So you may want to try rebooting and then see if that resolves the issue.
I’ve rebooted at least 3 times and nothing has changed. Bummed :frowning:
This happened to me just today when I updated to version 0.53.1, I noticed that when using another browser to pull up the config panel that the URL needed to be forced to end in “config/dashboard” and now it works again for me in Chrome sample below is what I put into Chrome and it pulled right up for me.
https://(home assistant IP address):8123/config/dashboard
