I’m havin problems with google integration, never works so i dont know how to make it work, i installed the google cast integration, but dont detect anything (i have 4 chromecast in the network)
I think the problem is I’m running HA Supervissor via docker and i cant do net=host, i dont know how to do it, or maybe Is another problem.
Is running on Debian 10, Thanks for the support
hello
for network host:
command line:
docker run --init -d \
--name homeassistant \
--restart=unless-stopped \
-v /etc/localtime:/etc/localtime:ro \
-v /PATH_TO_YOUR_CONFIG:/config \
--network=host \
homeassistant/home-assistant:stable
or with a compose:
version: '3'
services:
homeassistant:
container_name: homeassistant
image: homeassistant/home-assistant:stable
volumes:
- /PATH_TO_YOUR_CONFIG:/config
- /etc/localtime:/etc/localtime:ro
restart: unless-stopped
network_mode: host # <---------------------
Or if you use portainer u can move the container for host network too.
Or For only move the container with docker command line:
thanks for the answer
for what i see, the docker is runnin on my network host
But still cant find the chromecasts
