Vandana
(Vandana Dass)
May 3, 2022, 2:24pm
749
Hello guys,
Sorry if this off topic…
I have playlists in my /media folder. Now if I try to play it via nest mini by using media_play service. The Playlist is not played.
If I play the Playlist using vlc it plays just fine.
What am I doing wrong here?
Kindly guide
asanseau
(Alex)
June 27, 2022, 11:48am
750
Could this work, or (relatively) easily be adapted, to work with Sonos speakers and without Chromecast device?
OzGav
(Oz Gav)
June 27, 2022, 12:48pm
751
Is anyone outside of the UK able to get BBC radio 5 live working? And if so could you explain how?
asbril
(EndUser)
February 6, 2023, 10:34pm
753
Hi Bob (Hoe gaat het?)
I am Dutch (Rotterdammer) and living in Florida and use HA. I am not very technical but have used YAML a few times in HA. How can I add your integration to my HA in simple steps ?
drkbg
March 2, 2023, 4:44pm
755
I am using this for years and very happy with it.
Did someone figure out a way to integrate the radiostation icon so that is shows up in the standard mediaplayer card?
If I run the radiostation from tunein it shows the radiostation icon if I run it from home assistnat it doesn’t
1mfaasj
(Bowa)
October 9, 2023, 11:47am
756
Thanks!
One question; how to play the radio on multiple media players?
I mean how did you set this: media_player.everywhere
I created a number of speaker groups in the Google Home app. These automatically get brought into HA as additional media_players
jazzyisj
(Jason)
October 10, 2023, 1:06am
758
Just a heads up, that option is going to be limited going forward.
Well that sucks. I’d better set up a heap more groups quickly since they say existing groups will not be affected.
jazzyisj
(Jason)
October 10, 2023, 1:20am
760
I did the same! They didn’t specify a cutoff date but it still worked for me a few days ago.
I was planning on maybe adding another google speaker or two but I might have to start looking for a different eco system for the music and just keep the google stuff around for tts and google assistant stuff.
jazzyisj
(Jason)
October 12, 2023, 1:19am
762
Well that didn’t last long
psyciknz
(Psyciknz)
October 14, 2024, 7:17pm
764
Oldish topic…and I’ve been using this method for a while. But has anyone found a way of externalising the list of stations and urls, so that they can be read by home assistant and presented as a list?
sparkydave
(🇦🇺 Dave)
October 14, 2024, 11:54pm
765
One of my posts way back up this thread has my code that does this.
psyciknz
(Psyciknz)
October 15, 2024, 12:06am
766
do you know where? or can link to it.
So something like a json/yaml file with “station”: “url” that can be read and consumed by an automation/script?
sparkydave
(🇦🇺 Dave)
October 15, 2024, 12:17am
767
Actually, it was linked only a little way up… easy find.
psyciknz
(Psyciknz)
October 15, 2024, 12:20am
768
I did see that…The main bit I want to externalise is this:
media_content_id: >
{% if is_state("input_select.radio_station", "Hit 92-9") %} http://ic6ti.scahw.com.au/6ppm_128
{% elif is_state("input_select.radio_station", "Nova 93-7") %} http://streaming.novaentertainment.com.au/nova937
{% elif is_state("input_select.radio_station", "Mix 94-5") %} http://sc01.scahw.com.au/6mix_32
{% elif is_state("input_select.radio_station", "96FM") %} https://icy.ihrcast.arn.com.au/au_012_icy
{% elif is_state("input_select.radio_station", "80's 1") %} http://ic2ti.scahw.com.au/2easy_128
{% elif is_state("input_select.radio_station", "80's 2") %} http://18243.live.streamtheworld.com/T_RAD_80S_S01_SC?
{% elif is_state("input_select.radio_station", "OldSkool Hits") %} http://sc01.scahw.com.au/loveland_32
{% elif is_state("input_select.radio_station", "Old Skool Anthems") %} http://nebula.shoutca.st:8075/stream
{% elif is_state("input_select.radio_station", "Raw FM (dance)") %} https://frontend.stream.rawfm.net.au/i/syd-stream-192k.mp3
{% elif is_state("input_select.radio_station", "181FM Power (Todays Hits)") %} http://listen.181fm.com/181-power_128k.mp3?
{% elif is_state("input_select.radio_station", "181FM 90's Dance") %} http://listen.181fm.com/181-90sdance_128k.mp3
{% elif is_state("input_select.radio_station", "181FM Star 90's") %} http://listen.181fm.com/181-star90s_128k.mp3
{% elif is_state("input_select.radio_station", "181FM The Breeze") %} http://listen.181fm.com/181-breeze_128k.mp3
{% elif is_state("input_select.radio_station", "Heat Radio (RnB)") %} http://174.37.159.206:8106/stream
{% elif is_state("input_select.radio_station", "Fresh 92-7") %} http://live.fresh927.com.au:80/freshaac
{% elif is_state("input_select.radio_station", "DI Chill & Tropical House") %} http://pub1.diforfree.org:8000/di_chillntropicalhouse_hi
{% elif is_state("input_select.radio_station", "DI Disco House") %} http://pub1.diforfree.org:8000/di_discohouse_hi
{% elif is_state("input_select.radio_station", "DI Funky House") %} http://pub1.diforfree.org:8000/di_funkyhouse_hi
{% elif is_state("input_select.radio_station", "DI Liquid D&B") %} http://pub1.diforfree.org:8000/di_liquiddnb_hi
{% elif is_state("input_select.radio_station", "Aloha Joe's Relaxation Island") %} http://s2.voscast.com:7932/
{% elif is_state("input_select.radio_station", "Spectrum Fit") %} http://51.255.235.165:5292/
{% elif is_state("input_select.radio_station", "Energy FM Australia") %} http://s3.viastreaming.net:8502/
{% elif is_state("input_select.radio_station", "Jazz Relax") %} http://199.195.194.94:8036/stream
{% elif is_state("input_select.radio_station", "Australian Country") %} https://streaming.radio.co/s5ea3fdd1c/listen
{% elif is_state("input_select.radio_station", "Rebel FM") %} https://au1.fastcast4u.com/proxy/rblgc?mp=/stream
these if statements. I want that content, the station name and the url in a file outsode of the automation. The automation will read it for the list of station names input_select, and then use the station name and url for the selection before passing to the media player.
