Chromecast Radio with station and player selection
Try this:
    volume_level: >
     {% if is_state("input_select.chromecast_radio", "Huiskamer") %} '{{ ((states.media_player.speakers_huiskamer.attributes.volume_level)  + 0.5) | float }}'
     {% elif is_state("input_select.chromecast_radio", "Zolder") %}  '{{ ((states.media_player.speakers_zolder.attributes.volume_level) + 0.5) | float }}'
     {% elif is_state("input_select.chromecast_radio", "Overal") %}  '{{ ((states.media_player.huis.attributes.volume_level) + 0.5) | float }}'
     {% endif %}
I see whats wrong now, loose the quotes.
so:
    volume_level: >
     {% if is_state("input_select.chromecast_radio", "Huiskamer") %} {{ (states.media_player.speakers_huiskamer.attributes.volume_level | float) + 0.5 }}
     {% elif is_state("input_select.chromecast_radio", "Zolder") %}  {{ (states.media_player.speakers_zolder.attributes.volume_level | float) + 0.5 }}
     {% elif is_state("input_select.chromecast_radio", "Overal") %}  {{ (states.media_player.huis.attributes.volume_level | float) + 0.5 }}
     {% endif %}
Nice, this works! Thanks! Could you explain why the quotes need to be removed?
I’ve been playing with the code a bit and slowly learning more and more about HomeAssistant
Now I have the following code, based on Bob_NL and Daanje (for the automated start after selection). This is only for one room, still trying to figure out what works best. The idea now is to have tab for every room (and thus radio option for each room).
This is the code for the Script:
    radio_huiskamer:
    alias: Play Radio
    sequence:
      - service: media_player.volume_set
        data_template:
          entity_id: media_player.speakers_huiskamer
          volume_level: 0.2
      -  service: media_player.play_media
         data_template:
           media_content_id: >
            {% if is_state("input_select.radio_station_huiskamer", "Radio 538") %} http://18973.live.streamtheworld.com/RADIO538.mp3
            {% elif is_state("input_select.radio_station_huiskamer", "Q-Music") %} http://icecast-qmusic.cdp.triple-it.nl/Qmusic_nl_live_96.mp3
            {% elif is_state("input_select.radio_station_huiskamer", "3FM") %} http://icecast.omroep.nl/3fm-bb-mp3
            {% elif is_state("input_select.radio_station_huiskamer", "100% NL") %} http://stream.100p.nl/100pctnl.mp3
            {% elif is_state("input_select.radio_station_huiskamer", "Veronica") %} http://8543.live.streamtheworld.com/VERONICACMP3
            {% elif is_state("input_select.radio_station_huiskamer", "Sky Radio") %} http://8623.live.streamtheworld.com:80/SKYRADIOAAC_SC
            {% elif is_state("input_select.radio_station_huiskamer", "Arrow Classic Rock") %} http://91.221.151.155/listen.mp3
            {% elif is_state("input_select.radio_station_huiskamer", "Classic FM") %} http://19143.live.streamtheworld.com/CLASSICFM_SC
            {% elif is_state("input_select.radio_station_huiskamer", "BNR Nieuwsradio") %} http://icecast-bnr.cdp.triple-it.nl/bnr_mp3_96_03
            {% endif %}
           media_content_type: 'audio/mp4'
stopradio_huiskamer:
  alias: Stop radio
  sequence:
    - service: media_player.media_stop
      data_template:
volume_up_huiskamer:
  alias: Volume +
  sequence:
      data_template:
        volume_level: >
          {{ (states.media_player.speakers_huiskamer.attributes.volume_level | float) + 0.01 }}
volume_down_huiskamer:
  alias: Volume -
  sequence:
      data_template:
        volume_level: >
          {{ (states.media_player.speakers_huiskamer.attributes.volume_level | float) - 0.01 }}
How can i see the name of the station instead of Default Media Receiver?!
Are there any ideas, i have got an streaming URL that returns the title of the
played song!
Hey guys, if you did not find out yet - There is an easy way to get almost every .pls stream to work.
  1. Download .pls file
  2. Open .pls file with notepad++
  3. search for the “File1” line e.g. “File1=http://xy.station.fm:8000”
  4. copy URL and extend it with “/;stream.mp3” e.g. “http://xy.station.fm:8000/;stream.mp3
  5. use the extended URL and enjoy :smiley:
thanks to: Cannot stream *.pls radio stream to chromecast
Would it be possible to see your cube configuration to control the radio?
Of course. With cube i only control input select with radio station names. Flip 90 select next in input select. Flip 180 select previous. Shake turn on and off.
- id: '2005'
  alias: 'radio play with cube'
    - platform: event
      event_type: cube_action
      event_data:
        entity_id: binary_sensor.cube_158d000106132f
        action_type: shake_air
  condition:
    - condition: template
      value_template: >
        {% if is_state('media_player.chromecastaudio0667', 'off') %}
          true
        {% else %}
          false
        {% endif %}
    - service: switch.turn_on
      entity_id: switch.orvibo
    - service: input_number.set_value
        entity_id: input_number.volume_radio
        value: '0.15'
    - service: media_player.volume_mute
        entity_id: media_player.chromecastaudio0667
        is_volume_muted: "false"
    - service: input_select.select_option
      entity_id: input_select.radio_station
        option: "Antena"
- id: '2006'
  alias: 'radio next station with cube'
    - platform: event
      event_data:
        action_type: flip90
  condition:
      value_template: >
        {% if is_state('media_player.chromecastaudio0667', 'playing') %}
          true
        {% else %}
          false
        {% endif %}
    - service: input_select.select_next
- id: '2007'
  alias: 'radio previous station with cube'
    - platform: event
      event_data:
        action_type: flip180
  condition:
      value_template: >
          true
        {% else %}
          false
        {% endif %}
    - service: input_select.select_previous
- id: '2008'
  alias: 'radio set volume with cube'
    - platform: event
      event_data:
        action_type: rotate
      data_template:
        value: >
          {%if trigger.event.data.action_value | float > 0 %}
          {{  states.input_number.volume_radio.state |float + 0.05 }}
          {% else %}
          {{  states.input_number.volume_radio.state |float - 0.05 }}
          {% endif %}
- id: '2009'
  alias: 'radio stop with cube'
    - platform: event
      event_data:
  condition:
      value_template: >
          true
        {% else %}
          false
        {% endif %}
        option: "Off"
Thank you so much! Works great. I have one question however, how is your script when stopping? I see you have a option: "Off" in your action there but not sure how to add it to the script, any pointers?
Nice, here’s an automation to control the volume using the cube (rotate to right = volume up, rote to left = volume down.
- alias: Xiaomi Cube - Volume [Rotate]
    platform: event
    event_data:
      entity_id: binary_sensor.cube_158d000101bded
      action_type: rotate
  condition:
      - condition: state
        entity_id: input_select.cube_mode
        state: 'Radio'
      data_template:
        entity_id: media_player.home_group
        volume_level: >
          {{  states.media_player.home_group.attributes.volume_level | float + 0.05 }}
          {% else %}
          {{  states.media_player.home_group.attributes.volume_level | float - 0.05 }}
          {% endif %}
Works great!
This automation stops chromecast.
- id: '2002'
  alias: 'radio stop'
    - platform: state
      to: "Off"
Thanks. I have that but sometimes it jumps more then it should like 0.1 or 0.15. I never figured why.
Is it so that the automation for input_select is needed for the select to change radio station without having to press play afterwards?
You can do that with an automation indeed.
Thanks! It’s all working pretty good. I created a gist of what I’ve gathered, hope you all don’t mind.
Anything to improve upon here?
I also use google tts to announce next station.
It’s so perfect! I love the cube automations you guys did. Do you know if it’s possible to make it emphazise the pronunciation? The speech is a little dim, at least it is with the Norwegian language.
Somebody told me that amazon polly is better. But i don’t use it.
Does this works with google home speakers too?
For sure! I currently use 1 regular Google Home device, 3 Google Home mini’s and several Chromecast audio’s
