Chromecast Radio with station and player selection
I would say yes if your sonos speakers have a media_player entity. Having said that you might like to look at the new Music Assistant integration. GitHub - music-assistant/hass-music-assistant: Turn your Home Assistant instance into a jukebox, hassle free streaming of your favorite media to Home Assistant media players.
Is anyone outside of the UK able to get BBC radio 5 live working? And if so could you explain how? :slight_smile:
Hi Bob (Hoe gaat het?)
I am Dutch (Rotterdammer) and living in Florida and use HA. I am not very technical but have used YAML a few times in HA. How can I add your integration to my HA in simple steps :grinning: ?
I am using this for years and very happy with it.
Did someone figure out a way to integrate the radiostation icon so that is shows up in the standard mediaplayer card?
If I run the radiostation from tunein it shows the radiostation icon if I run it from home assistnat it doesn’t :frowning:
Thanks!
One question; how to play the radio on multiple media players?
I mean how did you set this: media_player.everywhere
I created a number of speaker groups in the Google Home app. These automatically get brought into HA as additional media_players.
Just a heads up, that option is going to be limited going forward.
Well that sucks. I’d better set up a heap more groups quickly since they say existing groups will not be affected.
I did the same! They didn’t specify a cutoff date but it still worked for me a few days ago.
I was planning on maybe adding another google speaker or two but I might have to start looking for a different eco system for the music and just keep the google stuff around for tts and google assistant stuff.
Well that didn’t last long :laughing:
Thankfully!
Oldish topic…and I’ve been using this method for a while. But has anyone found a way of externalising the list of stations and urls, so that they can be read by home assistant and presented as a list?
One of my posts way back up this thread has my code that does this.
do you know where? or can link to it.
So something like a json/yaml file with “station”: “url” that can be read and consumed by an automation/script?
Actually, it was linked only a little way up… easy find.
I did see that…The main bit I want to externalise is this:
media_content_id: >
          {% if is_state("input_select.radio_station", "Hit 92-9") %} http://ic6ti.scahw.com.au/6ppm_128
          {% elif is_state("input_select.radio_station", "Nova 93-7") %} http://streaming.novaentertainment.com.au/nova937
          {% elif is_state("input_select.radio_station", "Mix 94-5") %} http://sc01.scahw.com.au/6mix_32
          {% elif is_state("input_select.radio_station", "96FM") %} https://icy.ihrcast.arn.com.au/au_012_icy
          {% elif is_state("input_select.radio_station", "80's 1") %} http://ic2ti.scahw.com.au/2easy_128
          {% elif is_state("input_select.radio_station", "80's 2") %} http://18243.live.streamtheworld.com/T_RAD_80S_S01_SC?
          {% elif is_state("input_select.radio_station", "OldSkool Hits") %} http://sc01.scahw.com.au/loveland_32
          {% elif is_state("input_select.radio_station", "Old Skool Anthems") %} http://nebula.shoutca.st:8075/stream
          {% elif is_state("input_select.radio_station", "Raw FM (dance)") %} https://frontend.stream.rawfm.net.au/i/syd-stream-192k.mp3
          {% elif is_state("input_select.radio_station", "181FM Power (Todays Hits)") %} http://listen.181fm.com/181-power_128k.mp3?
          {% elif is_state("input_select.radio_station", "181FM 90's Dance") %} http://listen.181fm.com/181-90sdance_128k.mp3
          {% elif is_state("input_select.radio_station", "181FM Star 90's") %} http://listen.181fm.com/181-star90s_128k.mp3
          {% elif is_state("input_select.radio_station", "181FM The Breeze") %} http://listen.181fm.com/181-breeze_128k.mp3
          {% elif is_state("input_select.radio_station", "Heat Radio (RnB)") %} http://174.37.159.206:8106/stream
          {% elif is_state("input_select.radio_station", "Fresh 92-7") %} http://live.fresh927.com.au:80/freshaac
          {% elif is_state("input_select.radio_station", "DI Chill & Tropical House") %} http://pub1.diforfree.org:8000/di_chillntropicalhouse_hi
          {% elif is_state("input_select.radio_station", "DI Disco House") %} http://pub1.diforfree.org:8000/di_discohouse_hi
          {% elif is_state("input_select.radio_station", "DI Funky House") %} http://pub1.diforfree.org:8000/di_funkyhouse_hi
          {% elif is_state("input_select.radio_station", "DI Liquid D&B") %} http://pub1.diforfree.org:8000/di_liquiddnb_hi
          {% elif is_state("input_select.radio_station", "Aloha Joe's Relaxation Island") %} http://s2.voscast.com:7932/
          {% elif is_state("input_select.radio_station", "Spectrum Fit") %} http://51.255.235.165:5292/
          {% elif is_state("input_select.radio_station", "Energy FM Australia") %} http://s3.viastreaming.net:8502/
          {% elif is_state("input_select.radio_station", "Jazz Relax") %} http://199.195.194.94:8036/stream
          {% elif is_state("input_select.radio_station", "Australian Country") %} https://streaming.radio.co/s5ea3fdd1c/listen
          {% elif is_state("input_select.radio_station", "Rebel FM") %} https://au1.fastcast4u.com/proxy/rblgc?mp=/stream
          {% endif %}
these if statements. I want that content, the station name and the url in a file outsode of the automation. The automation will read it for the list of station names input_select, and then use the station name and url for the selection before passing to the media player.
Cos what you have currently is double handling. You have an input select with all the station names, then another section with the station names and urls. If you add to one and not the other, then it will break.
Yeah ok, I guess you could get each ‘slot’ to be a generic name and reference them to a single list that you edit perhaps in your secrets file or something.
I don’t actually use this anymore because this functionality is covered by Music Assistant and adding stations is easily done via it’s UI.
