- Post 3
Bin a long time with no tinkering back in the saddle
got presages detection to work … some watt… 95% accurate. close nuff for now, seems using WiFi + phone is not as accurate as i hoped. May be later ill use some GPS solution
Next topic… duck dns …
HUAWEI Home Gateway hg659 I HATE YOU… worst is i cant even replays it. using it as a “tv reserver” provided by the isp, and the wife will divorce me be for she will get rid of her sops.
now is just need to find out how to internet>router>google wifi>pi so far internet to router is easy. seams the rest is not working
http://hassio.local:8123 is not working normaly so im using http://hassio:8123 or direct ip. maby there is a hint
- Post 2
nod read was strangely easy. just pufff and it worked almost imitatively. finally i can do this
next topic hmmmmmmm
presages detection. that sound important and fun.
device_tracker:… copy past… nop copy some other stuff past… nop… hmmm add in rounder info… nop
i guess i spoke to early of cores there needed to be complicated…
googling … one hour… two hours… finally nmaping and reserve ip
its working
well interesting… im not at home now…
i guess i need more hours in googling but at least i got the tracker up and profile picture.
- Post 1
Finally got my raspberry pie and all ready disappointed with it.
the first post i read when google to see what sd card i need.
my BRAND NEW and first raspberry pie 3b+
is already obsolete o well i can re use it later for when i finally get starred on a different project i have been dreaming about that dose not need the extra power. Still its kinda cool how small it is in real life,
Starting to set up my Hassio: Googling… You-tubing… frustrations… reinstall… frustrations… reinstall… reinstall… its RUINING.
afters few hours of trying i got it ruining. i recommend that the “few” minutes should be marked as several minutes
and the WiFi setup iiisss more complected than im used to in this day and age.
next up samba shear all the youtoubers make it look easy… well yes when it works out of the box, but even when i copy there own text and save it goes back to the default
Taking a brake…
Finally got it working not relay sure what is different now but as long as it works im happy… or at least until i need to change some thing
next i need to get working is node red, that is going to be interesting i guess.
if you are asking why bother with node red. node red + hassio videos where what drew me to hassio in the first plas
(3 ikea lights, 1 ikea hub, 1 ikea remote, 2 generic zigbee lights not set up, 1 google home mini, google WiFi)
Current equipment is nothing special and Hassio is over kill but the possibility’s of it and the ability to grow with me is soooooo interesting.
The sad part is given that im a renter for the next year or 2 i cant hard wire any thing, and lot of the relay cool stuff is not going to be passable or cost prohibitive
