didnt find on this forum if xiaomi chuangmi 720p camera is supported by hassio. Only 17$
Iâm afraid this camera is not supported by hass. Unfortunately, I have two of them. Iâm interested on writing a firmware for that device, but I have no time at this moment.
Did you manage to get this to work?
i dont have this camera. I just was considering to buy it, but as i see, its not supported
This is my fallback camera configuration for no-name cheap cameras. It works most of the time:
- platform: mjpeg
mjpeg_url: http://192.168.1.205:13105/videostream.cgi?user=admin&pwd=**********
still_image_url: http://192.168.1.205:13105/snapshot.cgi
username: admin
password: *********
authentication: digest
(Your ip and port number may vary)
i use this cheap camera https://www.gearbest.com/ip-cameras/pp_312963.html?vip=4266414&gclid=CjwKCAiAt4rfBRBKEiwAC678KWtPRM35OIGjp7ZEzDt0ZZhsvhKoxt5DsHLfYqHDZJE4yu2zzW_JTxoCFrsQAvD_BwE
and this short configuration works for me
# Camera
camera:
- platform: ffmpeg
input: rtsp://192.168.31.29:554/onvif1
Works great! I did not have to install older version of official firmware (I had my camera fully updated). When I deployed tf_recovery.img (step 2.2) it automatically downgraded my camera. Then I configured mijia-720p-hack.cfg properly and itâs done. Took me ten minutes.
Now Iâm adding it to Hass.
I got the stream up, how do I get it in Hass, u have a config for me?
On configuration.yaml
camera:
- platform: ffmpeg
input: rtsp://YOUR_CAMERA_IP_HERE:554/live/ch00_0
Restart hass
Thanks, this indeed should work but I get no image. Should be me so I will look for a solution.
I have done some tests and Iâve found out the best solution: hass.io âmotion eyeâ plugin. Just install and configure it from hassio marketplace and then add it to home with
motioneye:
title: 'MotionEye'
icon: mdi:eye
url: 'http://IPaddress:blahblahblah'
Donât know why but I can acces the camera but it wonât show in Hass, no image available is the message. Motion eye wonât start either, âbad gatewayâ⌠Any idea?
Hi guys ⌠i have hacked my Xiaomi Chuangmi Camera and i would like to do 2 things âŚ
- use this cam with obs software to produce live streams (rtsp protocol)
- use this cam and insert it on my android IP Cam Viewer to access it from outside (router nat configuration)
Is it possible both ?
hello, can anyone send compiled files to this cmsxj01c camera?
Anyone tested with a CMSXJ16A ?
What firmware are workable
same question about CMSXJ16A. Or is there another way, how to get work in HA. Like connect 3rd party service to Xiaomi Home account?
Me too, and also a newer model: CMSXJ16A
Tryed procedures but itâs not working.
I have some cmsxj01c in the house that are working properly with the hack.
Any help?
I bought the same model (CMSXJ16A) and only now have found that there is no integration. Iâll follow up here.
