Hi all,
the past 3 days I spent some time to automate my deployment as I now maintain 4 installations of HA (parents, brother and some friends).
Every time I change something on the configs I would like to know if my config works correctly without check out from my local repository hosted on Gitea using Docker.
My CI/CD setup works find even with some custom components from different contributors hosted on GitHub.
My HA installation is also located on my QNAP in a Docker container using network_mode: host.
Assumed knowledge
- git
- docker
The following lines will describe a complete how-to. My setup was made on a QNAP using Container Station.
Docker-Compose
First of all you need to install some containers using the following docker-compose.yml file:
version: '3'
services:
gitea:
container_name: gitea
image: gitea/gitea:latest
restart: unless-stopped
environment:
- USER_UID=1000
- USER_GID=1000
- RUN_MODE=prod
ports:
- "3000:3000"
- "222:22"
volumes:
- /<some-folder>/gitea:/data
drone:
container_name: drone
image: drone/drone:latest
environment:
- DRONE_GITEA_SERVER=http://<your-ip-address>:3000/
- DRONE_GIT_ALWAYS_AUTH=false
- DRONE_RUNNER_CAPACITY=2
- DRONE_SERVER_PROTO=http
- DRONE_SERVER_HOST=<your-ip-address>:3001
- DRONE_TLS_AUTOCERT=false
- DRONE_NETWORK=cicd_default
- DRONE_RUNNER_NETWORKS=cicd_default
ports:
- "3001:80"
- "9000:9000"
volumes:
- /var/run/docker.sock:/var/run/docker.sock
- /<some-folder>/drone:/data
Note:
- Change with the path of your desired location
- Change with the ip of your container (in my case it’s the IP address of my QNAP)
Gitea Setup
- Open Gitea using http://:3000 and setup.
- Create a username and password for the administrator (bottom of the page)
- Add a new repository.
- Initialize it using the commands shown on the page.
Drone Setup
- Open Drone using http://:3001 and use the same administrator credentials you’ve setup on Gitea.
- Click on sync and wait for it to fetch the Gitea repository.
- Click on “Activate” and activate it on the next page.
- Go to “Settings” and add two new credentials:
secret name: ssh_username
secret value: <yourusername>
secret name: ssh_password
secret value: <yoursupersecretpassword>
Note
The above used credentials should be the admin user on your QNAP (for ssh and write permissions to folders).
Commit to Gitea
- Now that you’ve setup everything commit and push your code to your newly installed Gitea repository.
- Add a new file named
.drone.yml
with the following content to your repository and - change with the IP of your QNAP.:
kind: pipeline
steps:
- name: test
image: homeassistant/amd64-homeassistant
commands:
- echo "Downloading here_travel_time component"
- wget -O /tmp/here.zip https://github.com/eifinger/here_travel_time/archive/master.zip
- unzip /tmp/here.zip 'here_travel_time-master/custom_components/here_travel_time/*' -d /tmp/
- cp -R /tmp/here_travel_time-master/custom_components/here_travel_time ./custom_components/
- hass -c . --script check_config
- echo "Cleaning up custom components"
- rm -rf ./custom_components/here_travel_time
- name: deploy
image: appleboy/drone-scp
settings:
host: <your-ip-address>
username:
from_secret: ssh_username
password:
from_secret: ssh_password
port: 22
target: /share/VM/homeautomation/home-assistant
source:
- name: update
image: appleboy/drone-ssh
settings:
username:
password:
port: 22
script:
- /share/CACHEDEV1_DATA/.qpkg/container-station/bin/docker restart homeassistant
Note
- If you use custom components installed using hats or downloading them manually using GitHub, you need to add the also to your test environment.
- In this example I’ve added here_travel_time to show how it works.
- Don’t forget to clean up with rm -rf ...
after your test is completed .
steps:
- name: test
commands:
Thats it. If you have any troubles setting up I would love to help.
Here some screenshots of my setup:
Gitea
Drone
clone
test
deploy
update
