I have managed to configure some shell commands that seem to successfully mount some CIFS shares I have running on a macOS Server that I use to store my media files.
The shell commands look like this:
Blockquote
'mkdir /media/TV;mount -t cifs -o noserverino,username=username,password=password,uid=1001 //IP/TV /media/TV'
Blockquote
I know that the command has worked because if I look in the media browser I can see the existing media files there (created from a previous system), however at the command line (Using the advanced SSH terminal) I cannot see any files listed in the mounted folder.
I have also tried to use these mounted folders in some add-on’s I am running, whilst it can see the directories and write to them, the files the add-on creates (Sonarr) only appear on the home assistant machine and not on the actual network share.
I’m suspecting something to do with UID’s but even then I’m not sure, I can see the newly created files are owned by root on the HA server.
I’m running HaasOS 10.2 and Home Assistant 2023.5.4 with Supervisor 2023.04.1
