Sometimes I don’t like to say Alexa turn on the light. Sometimes don’t have automation in place (or not working ). Sometimes I am too lazy to go to a phisical switch, or turn on the smartphone.
Is there any hardware that can send a signal to HA after clapping the hand or similar?
I wish they would just make the on button a normal power switch. Then you could at least heat it up with a smart switch. I have the same problem with my Keurig, so I know what you’re talking about.
I know it’s pretty low-tech, but I just bought a cheapie $10 Mr. Coffee. Plugged it into a 433mhz smart outlet, stuck the switch to the “ON” position, and I prep my pot in the evening when I go to bed. When the motion sensor in the hall outside my bedroom notices first motion in the morning, Home Assistant turns it on.
Can’t decide on how many cups using this method, but at least the coffee is ready by the time I make my way into the kitchen.
I’ve been meaning to put a water sensor in the bottom of the pot as a safety fallback for those nights I forget to make the coffee before bed, but I will probably have to wake up to a heated but empty carafe before I’m sufficiently motivated to do that.
I’d be more worried of an exploding carafe than a fire, but yes, this is the reason I want to add the sensor. - So the pot doesn’t kick on if it’s empty.
I am saying it because it happened to me. I used those cheap RF switches, I click turn off, but in reality it did not (not very reliable sometimes), and the devive stayed on for a long time.
