Clean crashed SD card
I had a HASSOS setup on a Raspberry Pi400 (Sandisk extreme 64gb mSD card) crash and haven’t been able to reuse the card afterwards. Surface tests on the card did not reveal any issue, and the only thing that keeps me thinking that the card is ok but with some partition issue is this info from R-Studio:
In the past what I’ve done with situations like these is to use the Pi Imager tool to format the card, but that did not work either.
I’ve tried a lot of different things (like diskpart) and partition management applications, but so far all return errors and only R-Studio shows that there is some strange partition issues with the card but that might not mean that the card is dead.
All other apps and disk manager show the drive with only one raw segment, which none can activate.
Any suggestions on how to clean-up the card, on Windows ou mac?
The only Pi I use is my MQTT broker, but when I have an SD card that I can’t format, I have had some success using the SD Card Duplicator on Raspian to duplicate my current boot device. Then that SD card can be formatted or flashed on the PC.
