Hi!
I have Home Assistant Yellow POE kit. I have added CM4 4GB RAM/16GB eMMC and an NVME drive (970 EVO Plus MZ-V7S500 that is recommended on FAQ page).
I was experimenting a bit with installation, disk, partitions and I now I want to start fresh so I want to clean install Home Assistant on my device. I used option 1 from the official installation guide (link). I am doing all the steps, getting correct led behaviour, but for the love of God I can’t wipe the NVME and I keep booting to the old installation. Is using option 2 (rpiboot) the only way I can do it? Am I missing any steps other than doing the red + blue button to to clean install with wipe of the drives?
With problems above I looked around the guides and documentation. According to the reinstall page linked above, boot order should be eMMC → NVMe SSD → USB flash drive. So I thought that I remove the NVME, install HA to eMMC, reinstall the drive and from ssh terminal I’ll be able to wipe the NVME so I can move the files there. I tried that but it doesn’t work as I expected and once I install the NVME I boot to old installation.
I saw that you can press blue button within 5 seconds of booting to installer, to directly install to NVME. I tried that and indeed it installed to the NVME. But in System > Hardware > All Hardware I can’t see my Samsung drive (I don’t know if I should but I saw some YouTube videos that people had them displayed there). Also I don’t know if this method is equivalent to doing the “Move datadisk” option from Storage menu? When I try that I see that it shows my NVME as the current and allows me to move to NVME:
So beside the main question here being is there a way to wipe my eMMC and NVME and do a clean install (on either) I have two more if you don’t mind addressing.
- Is installing directly to NVME equivalent of doing “Move datadisk”?
- Can I under-provision a drive and use it as target of “Move datadisk”? Let’s say setup 500GB NVME to 100GB partition?
Any ideas would be appreciated
Thank you in advance,
Michal
