Clean up map entities (rename or delete)
I have created 3 zones, but two are named incorrectly. I cannot see to delete or just rename these. I know that home stays and that’s fine but I misnamed the other 2.
Settings - Zones
All the zones should be listed on the right hand side of the page.
Click on the pencil button next to the zone you want to edit.
It has a diagonal line through it, so you can’t
That usually means that the Zone was configured manually in YAML, so you will need to find it and edit it either in configuration.yaml or whatever file you have placed it in.
I got it now; I was able to delete the 2 extras and the missed name home I was finally able to rename. I wish I could remember everything that I did, but I was trying combinations of all of the advice and together, it worked. I wish I could share more. I know that I used the Actions, services and also states in dev tools.
