My diskspace usage was always growing and I was wondering what was using all the diskspace.
It was not the database file (400MB) or the logfile (2MB).
I found that there were old container images lingering around. Cleanup of these old images saved me 24GB of diskspace.
I used portainer to cleanup these old images, but that’s not the idea.
Shouldn’t hassio cleanup these old container images?
Bondo2
(Bondo2)
October 2, 2022, 3:20am
2
I have the same issue and it has been bugging me for some time now. I have been manually doing docker image prune manually but this is not the solution. The system should be self managing/healing and requiring a techie to run it.
Supervisor does clean up after itself. But those are not addon images and you’re using portainer so you’re running unsupported and therefore all bets are off. Supervisor does not expect unsupported software (non-addon images and containers) to be present so it has no inherent handling for them
I may have a similar issue. Running out of space. df -h says disk is full, du says there is plenty of space left. Posted a question here:
Got notification today that I am out of storage.
System: HAOS on proxmox VM. 16GB RAM, 64GB SSD.
Deleted some backups, now HA reports as 90% used. Checked it in shell:
df -h reports 56GB used.
gdu reports a total of 25GB used.
du -h / | sort -rh | head -n 20 reports ~25GB worth of folders.
docker system df says there are 23GB of images.
So the numbers don’t add up and I don’t know where/how else to look.
[Screenshot 2024-06-24 132255]
[Screenshot 2024-06-24 132139]
[Screenshot 2024-…
docker system df says I have 23GB in images. How do I clean this up?
I am running HAOS on proxmox vm, nothing “unsupported”.
Can I just run docker system prune ? Will this break anything?
XauMasala
(Jaume)
September 15, 2024, 8:08am
5
I’m in the same situation, for years, and nobody said what is expected that we make to clean it. In the past I used portainer to clean old images, but now portainer is unsupported so I guess this wan’t the way to clean old images. So, What is expected the people must do to clean unused images of old versions of addons?
cogneato
(cogneato)
September 15, 2024, 8:17am
6
It should happen automatically on a healthy system, but the command ha su repair can be used.
Haldi
(Haldi)
August 17, 2025, 10:41am
7
i think it does…
/mnt/data/docker/overlay2 # docker system df
TYPE TOTAL ACTIVE SIZE RECLAIMABLE
Images 18 14 7.977GB 2.912GB (36%)
Containers 14 14 52.4MB 0B (0%)
Local Volumes 0 0 0B 0B
Build Cache 0 0 0B 0B
It’s just that some docker Container use way too much Space… and i have no clue which one. as the “Local Volumes” are shown as 0 on HAOS
/mnt/data/supervisor/addons/data # du -h -d 1 /mnt/data/docker | sort -hr | head -n 10
22.1G /mnt/data/docker/overlay2
46.4M /mnt/data/docker/image
1.6M /mnt/data/docker/containerd
796.0K /mnt/data/docker/containers
132.0K /mnt/data/docker/network
116.0K /mnt/data/docker/buildkit
28.0K /mnt/data/docker/volumes
16.0K /mnt/data/docker/plugins
8.0K /mnt/data/docker/tmp
at least the prune did nothing at all…
/mnt/data/docker/overlay2 # docker system prune
WARNING! This will remove:
- all stopped containers
- all networks not used by at least one container
- all dangling images
- unused build cache
Are you sure you want to continue? [y/N] y
Total reclaimed space: 0B
Edit: Correction! If you want to get rid of empty Volumes, you need this to add --volumes to prune!
docker system prune --volumes
/mnt/data/docker/overlay2 # du -h -d 1 /mnt/data/docker/overlay2 | sort -hr | head -n 10
14.1G /mnt/data/docker/overlay2
2.3G /mnt/data/docker/overlay2/ccbf8ec1c2b83706012e9a16083a75cbe21599b5ac49f3e8759a5bb44b8f6100
1.4G /mnt/data/docker/overlay2/7b0110ea6beea7c13ad417d3d7fda80a202ac0f23352bf9e5f6ad85e34276523
1.4G /mnt/data/docker/overlay2/5f33890497f1a1a134ab2a3a57db6acb34a7df861f5cc2a8a3ceb443f19bb40e
1015.7M /mnt/data/docker/overlay2/76a1390933bc7526ad38257b342aa0ca6f0cddedd97995c7e8343e2b809ee9bb
917.5M /mnt/data/docker/overlay2/a41980376d0f863012689a5a02e7c47faf42baa7bcab705f6700a87714645d70
904.5M /mnt/data/docker/overlay2/188565b2e5a5f99b2aa58c319ba0da4ec26a2619cb08833404d8c522b4ccef0c
612.8M /mnt/data/docker/overlay2/a3934f2b13917f5e7326b2705ce7272e1eb087f7dbaf67c3b21c3bb4367f2ea6
517.4M /mnt/data/docker/overlay2/1290282dcd7514eeac6e2589a2e4b97fef2355850db6a11907d41e55bbe2e290
426.5M /mnt/data/docker/overlay2/2be6606bc38b847bf4a83add679030c7e65878bda31890a00965e82c253b30c8
this brought down the size from 22gb to 14gb
Edit: even -verbose doesn’t show more storage info:
/mnt/data/docker/overlay2 # docker system df -v
Images space usage:
REPOSITORY TAG IMAGE ID CREATED SIZE SHARED SIZE UNIQUE SIZE CONTAINERS
ghcr.io/home-assistant/qemux86-64-homeassistant 2025.8.2 64478dee3905 43 hours ago 2.03GB 0B 2.028GB 1
ghcr.io/home-assistant/amd64-hassio-cli 2025.08.1 d25aa8d722c4 4 days ago 54.4MB 44.97MB 9.387MB 1
ghcr.io/home-assistant/amd64-hassio-dns 2025.08.0 c480c7db0f97 6 days ago 69.6MB 44.97MB 24.66MB 1
ghcr.io/home-assistant/amd64-hassio-multicast 2025.08.0 257a3bb07cf0 6 days ago 45.1MB 44.97MB 120.1kB 1
ghcr.io/home-assistant/amd64-hassio-audio 2025.08.0 99c24258d3ed 6 days ago 81.3MB 44.97MB 36.32MB 1
ghcr.io/home-assistant/amd64-hassio-supervisor 2025.08.1 1cbed2678902 10 days ago 418MB 44.97MB 373.4MB 1
homeassistant/amd64-addon-piper 1.6.3 42169a177d8a 12 days ago 225MB 101.3MB 123.7MB 1
ghcr.io/esphome/esphome-hassio 2025.7.5 c115daa35c52 12 days ago 592MB 74.83MB 517.1MB 1
ghcr.io/hassio-addons/ssh/amd64 21.0.2 0d9bf25d66a9 6 weeks ago 327MB 8.309MB 318.2MB 1
homeassistant/amd64-addon-speech-to-phrase 1.4.1 a4152e3375f9 6 weeks ago 1GB 101.3MB 899.5MB 0
homeassistant/amd64-addon-whisper 2.6.0 e1a39b7344fb 2 months ago 1.48GB 101.3MB 1.382GB 0
ghcr.io/hassio-addons/vscode/amd64 5.19.3 177791530998 3 months ago 970MB 74.83MB 895.2MB 1
ghcr.io/home-assistant/amd64-hassio-observer 2025.02.0 b22cb2cf1712 5 months ago 10.1MB 0B 10.06MB 1
ghcr.io/hassio-addons/influxdb/amd64 5.0.2 91167dbd8e7e 6 months ago 523MB 0B 522.7MB 1
ghcr.io/hassio-addons/glances/amd64 0.21.1 453b86cb1912 16 months ago 104MB 7.377MB 97.11MB 1
homeassistant/amd64-addon-openwakeword 1.10.0 d78403b2b81b 17 months ago 305MB 0B 305.1MB 0
homeassistant/amd64-addon-configurator 5.8.0 5b6b5dab6789 18 months ago 117MB 7.377MB 109.2MB 1
ghcr.io/hassio-addons/ubuntu-base 9.0.2 8e5500cdd97f 20 months ago 96.7MB 0B 96.73MB 0
Containers space usage:
CONTAINER ID IMAGE COMMAND LOCAL VOLUMES SIZE CREATED STATUS NAMES
b3542d4d2cec ghcr.io/home-assistant/qemux86-64-homeassistant:2025.8.2 "/init" 0 49MB 13 minutes ago Up 13 minutes homeassistant
8c47cee74417 homeassistant/amd64-addon-configurator:5.8.0 "/init" 0 17.9kB 2 hours ago Up 2 hours (healthy) addon_core_configurator
ca1d2e56ed1e homeassistant/amd64-addon-piper:1.6.3 "/init" 0 17.6kB 2 hours ago Up 2 hours (healthy) addon_core_piper
5657db4995c2 ghcr.io/hassio-addons/influxdb/amd64:5.0.2 "/init" 0 325kB 2 hours ago Up 2 hours addon_a0d7b954_influxdb
4ab2e4e044c0 ghcr.io/hassio-addons/glances/amd64:0.21.1 "/run.sh" 0 15.1kB 2 hours ago Up 2 hours addon_a0d7b954_glances
460f4428396d ghcr.io/hassio-addons/vscode/amd64:5.19.3 "/init" 0 324kB 2 hours ago Up 2 hours (healthy) addon_a0d7b954_vscode
f6d3729bb7c0 ghcr.io/hassio-addons/ssh/amd64:21.0.2 "/init" 0 163kB 2 hours ago Up 2 hours addon_a0d7b954_ssh
8970c5452280 ghcr.io/esphome/esphome-hassio:2025.7.5 "/init" 0 2.43MB 2 hours ago Up 2 hours addon_5c53de3b_esphome
8c4ddf7a24a1 ghcr.io/home-assistant/amd64-hassio-multicast:2025.08.0 "/init" 0 13.7kB 2 hours ago Up 2 hours hassio_multicast
2ea21f8b26d8 ghcr.io/home-assistant/amd64-hassio-audio:2025.08.0 "/init" 0 17.2kB 2 hours ago Up 2 hours hassio_audio
479175c7c912 ghcr.io/home-assistant/amd64-hassio-dns:2025.08.0 "/init" 0 14.5kB 2 hours ago Up 2 hours hassio_dns
e0fd382de586 ghcr.io/home-assistant/amd64-hassio-cli:2025.08.1 "/init" 0 12.9kB 2 hours ago Up 2 hours hassio_cli
ea26909fb899 ghcr.io/home-assistant/amd64-hassio-supervisor:latest "/init" 0 15.4kB 2 days ago Up 2 hours hassio_supervisor
024550f0d6de ghcr.io/home-assistant/amd64-hassio-observer:2025.02.0 "/usr/bin/observer" 0 0B 4 months ago Up 2 hours hassio_observer
Local Volumes space usage:
VOLUME NAME LINKS SIZE
Build cache usage: 0B
CACHE ID CACHE TYPE SIZE CREATED LAST USED USAGE SHARED
