I have a sensor collected via zigbee2mqtt - MQTT that is generating a large amount of useless data stored in attributes. I will ask for zigbee2mqtt correction.
Waiting for correction, is there a way to cleanup useless attributes to avoid exploding database ?
I only need to keep the attributes in bold !
Thanks for your help,
Regards,
Pierre
SELECT
FROM states
where
entity_id = “sensor.linky_easd02”;
state_id | domain | entity_id | state | attributes |
35275309 | sensor | sensor.linky_easd02 | 15970.036 | ** {“state_class”:“measurement”, “active_enerfy_out_d01”:7791.507,“active_enerfy_out_d02”:15970.036,“active_enerfy_out_d03”:null,“active_enerfy_out_d04”:null,“active_power”:2098,“active_power_max”:6663,“active_power_ph_b”:3250,“apparent_power”:6002,“available_power”:9,“average_rms_voltage_meas_period”:240,“current_date”:“H220306224851”,“current_index_tarif”:1,“current_price”:“HEURE CREUSE”,“current_summ_delivered”:23761.519,“current_tarif”:“H PLEINE/CREUSE”,“current_tier10_summ_delivered”:0,“current_tier1_summ_delivered”:7791.483,“current_tier2_summ_delivered”:15970.036,“current_tier3_summ_delivered”:0,“current_tier4_summ_delivered”:0,“current_tier5_summ_delivered”:0,“current_tier6_summ_delivered”:0,“current_tier7_summ_delivered”:0,“current_tier8_summ_delivered”:0,“current_tier9_summ_delivered”:0,“days_number_current_calendar”:null,“days_number_next_calendar”:null,“days_profile_current_calendar”:null,“days_profile_next_calendar”:null,“drawn_v_a_max_n1”:5563,“linkquality”:75,“message1”:“PAS DE ###MESSAGE”,“message2”:"",“meter_serial_number”:“06206118xxxx”,“power_threshold”:9,“relais”:1,“rms_current”:25,“rms_current_max”:65535,“rms_voltage”:240,“site_id”:“2145658453xxxx”,“software_revision”:2,“start_mobile_point1”:null,“start_mobile_point2”:null,“start_mobile_point3”:null,“status_register”:“003A0000”,“stop_mobile_point1”:null,“stop_mobile_point2”:null,“stop_mobile_point3”:null,“tomorrow_color”:"",“update”:{“state”:“idle”},“update_available”:false,“unit_of_measurement”:“kWh”,“device_class”:“energy”,“friendly_name”:“Linky EASD02”,“last_reset”:“1970-01-01T00:00:00+00:00”} |
35275336 | sensor | sensor.linky_easd02 | 15970.036 | {“state_class”:“measurement”,“active_enerfy_out_d01”:7791.507,“active_enerfy_out_d02”:15970.036,“active_enerfy_out_d03”:null,“active_enerfy_out_d04”:null,“active_power”:2098,“active_power_max”:6663,“active_power_ph_b”:3250,“apparent_power”:6002,“available_power”:9,“average_rms_voltage_meas_period”:240,“current_date”:“H220306224851”,“current_index_tarif”:1,“current_price”:“HEURE CREUSE”,“current_summ_delivered”:23761.519,“current_tarif”:“H PLEINE/CREUSE”,“current_tier10_summ_delivered”:0,“current_tier1_summ_delivered”:7791.483,“current_tier2_summ_delivered”:15970.036,“current_tier3_summ_delivered”:0,“current_tier4_summ_delivered”:0,“current_tier5_summ_delivered”:0,“current_tier6_summ_delivered”:0,“current_tier7_summ_delivered”:0,“current_tier8_summ_delivered”:0,“current_tier9_summ_delivered”:0,“days_number_current_calendar”:null,“days_number_next_calendar”:null,“days_profile_current_calendar”:null,“days_profile_next_calendar”:null,“drawn_v_a_max_n1”:5563,“linkquality”:78,“message1”:“PAS DE MESSAGE”,“message2”:"",“meter_serial_number”:“06206118xxxx”,“power_threshold”:9,“relais”:1,“rms_current”:25,“rms_current_max”:65535,“rms_voltage”:240,“site_id”:“2145658453xxxx”,“software_revision”:2,“start_mobile_point1”:null,“start_mobile_point2”:null,“start_mobile_point3”:null,“status_register”:“003A0000”,“stop_mobile_point1”:null,“stop_mobile_point2”:null,“stop_mobile_point3”:null,“tomorrow_color”:"",“update”:{“state”:“idle”},“update_available”:false,“unit_of_measurement”:“kWh”,“device_class”:“energy”,“friendly_name”:“Linky EASD02”,“last_reset”:“1970-01-01T00:00:00+00:00”} |
