I testing out the Unfi device tracker and had it set to track all new devices. Forgot to turn it off after I got what I wanted and now I have a ton of devices being tracked in history that I do not want. Is there a way to clear out all the history records and start fresh? this way it only picks up on the devices that I have set to track.
Delete \hassio\config\home-assistant_v2.db and restart.
That worked, thank you!
I deleted home-assistant_v2.db, excluded entity in recorder component, restarted, but I still see history for the excluded component. Where elsewhere are history data stored?
recorder:
purge_keep_days: 3
purge_interval: 1
exclude:
entities:
- sensor.business_keypad
- sensor.home_keypad
- binary_sensor.servis__motion
- binary_sensor.servis__door
- binary_sensor.shop__front_door
- binary_sensor.shop__motion
- binary_sensor.warehouse
I can automatically have this done for the history of a month old
Hi
I deleted this file and now my HA will not start up!
You deleted only “home-assistant_v2.db”, correct? Something else would be causing the issue. I’ve had to delete the file numerous times due to database corruption, and never had an issue.
thank’s a lot for this tips ! It fixed a 2 days head scratching issue
It is always a good idea to stop the Home Assistant host first before deleting the home-assistant_v2.db file.
