I would like to clear the input_text value in an automation (in order to have a nicer history-graph).
I tried to leave the value blank in the automation
I could have sworn this was the first thing I tried. Nevertheless I tried it ‘again’ and now it works perfectly. Thanks a lot for the quick and correct answer!
This used to work flawlessly…for some reason it stopped working for me now.
…EDIT: I’ve pinpointed the reason: it’s refreshing the dashboard. It seems the solution above works as before and the field is emptied, but the empty text value is no longer automatically updating into the dashboard, but the screen needs to be refreshed in order to see the changed value. This is unfortunate and annoying, but not related to this thread.
