I tried implementing the new scheme fr notifications and wanted to use clear_notification for my GFs iPhone. Sadly, this doesn’t work at all.
I’m using the same syntax for my android phone with node-red, so it should be working. I even tried the examples given in the Docs in the developer tools:
using:
service: notify.mobile_app_iphone_von_fine
title: "Motion Detected in Backyard"
message: "Someone might be in the backyard."
tag: "backyard-motion-detected"
Unfortunately, clearing notifications on iOS has a gotcha that we can’t work around (without Apple giving us permission, which they declined) – it needs to wake the app and instruct it to clear the notification. If you use the app somewhat regularly, it’ll be fairly reliable, but if you are mostly using it for notifications the system will not grant it permission to be woken up.
Yeah, this should be noted. It’s worth mentioning that these limitations are hard to gauge without releasing it (so the actual limitations are still being found out, so thanks for reporting), and I was hoping Apple would grant us the special permission necessary to make it reliable.
I believe launching the app about once per week is all that is necessary to keep iOS launching the app, but I do not know the exact rules enough to say.
Gonna try this out repeatedly throughout the next days!
Thanks for your answer!
Any way to emphasize the need towards apple? I guess everything is happening in private and there is no “ticker” where we could chime in?
Unfortunately the request is private, yeah. I plan to submit it again hopefully with a more compelling case because, imo, we absolutely qualify for the use case the special permission is designed around.
Damn. Well at least I know I’m not going crazy now.
It’s been working consistently on my iPad, but not on my iPhone. I use my HA app consistently though on my phone, so I’m still not sure why its not working…
