Clear / Reset delay
Hi, I have a light with a fan connected in the powder room. I have a 10 min delay on the switch so if the room needs extra ventilation, you can leave the light switch on and then it will automatically turn off after 10min.
The problem is the delay timer keeps running if the switch is turned off. If someone goes in after say 9 minutes, the light will turn off after 1 min.
I am trying to get clear the delay that is running or reset the delay to 0 seconds if the switch is turned off ready for a new 10min delay when it is turned on again. I haven’t been able to do it.
Any help is appreciated.
output:
  # status led
  - platform: gpio
    pin: GPIO4
    inverted: true
  # Top (or only) button
  - platform: gpio
    pin: GPIO13
light:
  # status Led
  - platform: binary
    name: "${friendly_name} status_led"
    output: relay0
  - platform: binary
    output: relay1
    on_turn_on:
     - delay: 600s
     - light.turn_off: pwdr_light
   on_turn_off:
    - delay: 0s # I want to reset the delay for the next time the light is turned on
# Buttons
binary_sensor:
  - platform: gpio
    pin:
      number: GPIO16
      mode: INPUT
      inverted: True
    #toggle relay on push
    on_press:
      - light.toggle: pwdr_light
