The updated version of the theme for HA 0.101 is now available in the first post.
The bad news
The button design with a blue background and grey knob when checked is not possible anymore. Maybe they will change this in the future. I will update the theme as soon as the grey knob is possible again.
The good news
I fixed the background color for the new entity registry.
You don’t need to set the background image on every page now. One option in the theme is enough.
I updated the theme to disable the card shadows again after the old option was broken.
I added styles for the lovelace slider (input_number).
I got a token and all but I have issues with HACS therefore I tried restarting HA and it indexed from the beginning. Therefore I reached the limit.
I will open an issue.
@naofireblade
Nice looking theme. For your information, URLs in the standard markdown-card gets this dark color. Maybe set another default color for the theme.
Yep thats a known problem. The header color is the link color in Home Assistant . Only way is to use the compact header plugin. Then u can apply this solution: Clear Theme Dark
I have an issue with all my themes with a background image since release 0.99, but I haven’t received any help on the dedicated topic I created.
Basically, my theme is properly displayed when I access my HomeAssistant webpage, but after browsing between my different views and coming back to the first view, the background image disappears. I need to refresh the page so that it is displayed again.
I have not changed my configuration since 0.99, but I haven’t seen any breaking change. Has anyone noticed this problem before ?
Thanks for your help!
Any chance you can get around on adding those? It’s still usable, and I like this theme way more than those annoyances would drive me to search for another, but if you even find some time it’d be a great fix
