I am new to the Home Assistant world and just bought myself a Raspberry Pi 4 (model b) with a 64 gb micro sd card. I asked this question yesterday on Home Assistant Discord server and no one were able to help. They did prompt me to buy a micro hdmi cable to get the log on screen and see what was going on. The problem:
I did install the Home Assistant OS 11.5 (RPI 4 / 400) according to the guide from Home Assistant webpage (Raspberry Pi - Home Assistant). I did it by using the Raspberry Pi Imager v1.8.5.
The installation did work, and i got a message to unload the sd card.
When I enter the power button into the Raspberry Pi 4, (I also have entered the sd card to the slot underneath prior to connecting the powercord) it boots up (green light flickering beside the static red light in front). I have an ethernet cable connected to the RPI 4 and its connected to the router, same local network as my computer.
However, I am unable to connect through the browser by either homeassistant.local:8123 or homeassistant:8123. I dont see any RPI 4 / HA / Home Assistant either in my router, so I dont find any IP adress for it. I have also tried to use Fing without success.
I have tried to flash/re-install the HA on my Sd card multiple times withoiut luck. Do you guys have any suggestions on what might be the issue here?
The “Cannot connect…” message keeps repeating until a new line says “[Warn] Home Assistant CLI not starting! Jump into emergency console…”
And then its just sitting there doing nothing else.
Anyone have any ideas?
Tnx in advance
