Click mouse trigger
Salve a tutti.
Avrei bisogno di “triggare” un evento geneato da un click del mouse in una determinata card per gestire una card condizionale.
Chi mi può dare una dritta ? Grazie
Ciao Sandro - benvenuto!
Please keep it in English. According to google translate, you want to capture the click on a specific card to be able to show a conditional card? The easiest way to do so is with an input_boolean.
If that’s your goal, you can drop your card config for the existing card (where the tap needs to be captured) and the new conditional card you want to be shown - and I will show you how to proceed.
Thank you for your help. I await indications.
@viesse — M1ke is asking you to include the code for:
  • the card that you want to click on
  • the conditional card you want to show
type: vertical-stack
cards:
  • type: thermostat
    entity: climate.termostato_caldaiamb
    name: Termostato Montebello
  • type: conditional
    conditions: []
    card:
    type: history-graph
    entities:
    - entity: climate.termostato_caldaiamb
    hours_to_show: 36
    refresh_interval: 0
I hope whoever is of help to you
Over to @M1ke
@viesse In future, please use the code block feature to format code properly:
@viesse
  1. create an input_boolean (impostazioni/aiutante/aggiungi aiutante/commutatore) [configuration/helpers/add helper/toggle], called “Corso Termostato Caldaiamb”
  2. go to impostazioni/controlli del server [configuration/server controls] and click “riciarica input booleani” [reload input booleans]
Then you can use the following code:
cards:
  - type: thermostat
    hold_action:
      action: call-service
      service: input_boolean.toggle
      service_data:
        entity_id: input_boolean.corso_termostato_caldaiamb
  - type: conditional
    conditions:
      - entity: input_boolean.corso_termostato_caldaiamb
        state: 'on'
    card:
      type: history-graph
      entities:
      hours_to_show: 36
      refresh_interval: 0
Now, when you long-press the thermostat card it shows/hides the history-graph card.
Thanks for mediating, @Troon :+1: :smiley:
No problem. I’m always amazed by people who manage to get anything working at all when the system is not in their first language, but I think your “you can drop your card config for the existing card” didn’t get understood.
Absolutely! Might use different words next time :wink:
I do not understand
3
  • copia e incolla il mio codice
  • premere a lungo carte termostate -> visualizzare/nascondere il corso
thank you, but it doesn’t work. Where should I do the long click?
cards:
  • type: thermostat
    hold_action:
    service_data:
    entity_id: input_boolean.pippo
  • type: conditional
    conditions:
    • entity: input_boolean.pippo
      state: ‘on’
      card:
      type: history-graph
      entities:
      • entity: climate.termostato_caldaiamb
        hours_to_show: 36
        refresh_interval: 0
Hmm shit, I just realized that the thermostat card does not support tap_action/hold_action…
lo, lo faro ? Grazie
can I add a button under the tab or do you have another solution?
yes, try this (there are many options):
cards:
  - type: thermostat
  - type: entities
    entities:
    - type: buttons
      entities:
        - entity: input_boolean.pippo
          name: whatever you want
  - type: conditional
    conditions:
        state: 'on'
    card:
      type: history-graph
      entities:
      hours_to_show: 36
      refresh_interval: 0
this works perfectly. It would have been interesting if it also worked with long press. Anyway many thanks
1000 thanks to you too
cards:
  - type: thermostat
  - type: horizontal-stack
    cards:
      - type: button
        tap_action:
          action: toggle
        entity: input_boolean.setup
        show_name: false
        icon_height: 20px
        show_icon: true
        icon: 'mdi:hammer-wrench'
      - type: button
        tap_action:
          action: toggle
        entity: input_boolean.graph
        show_name: false
        icon_height: 20px
        show_icon: true
        show_state: false
        icon: 'mdi:chart-line'
  - type: conditional
    conditions:
      - entity: input_boolean.graph
        state: 'on'
    card:
      type: history-graph
      entities:
      hours_to_show: 24
      refresh_interval: 0
  - type: conditional
    conditions:
      - entity: input_boolean.setup
        state: 'on'
    card:
      type: entities
      entities:
        - entity: input_datetime.orario_giorno
        - entity: input_number.temperatura_giorno
        - entity: input_datetime.orario_notte
        - entity: input_number.temperatura_notte
Many thanks
