It would be great to have an option that allows IP Addresses displayed in LoveLace to be clickable. I have lots of Tasmota devices and IP Address is an enabled entity. Would then be able to click the IP Address in the UI to open a new tab with the Tasmota UI for that device.
You could use the weblink entity:
- type: weblink
url: http://192.168.1.1
Thanks for the option but I would then need to configure this for each device specifically rather than just enabling the IP Address entity.
I use dhcp on all tasmota devices since tasmota integration. Not happy to set everything back to static and manually make new lists
Perhaps the tasmota integrations devs can add a few extra column in the view of the tasmota integration ?
column with clickable ip and tasmota version would be great. Both data is already known of the tasmota devices. Just missing in the overview of the entities
Maybe a combination of Tasmota publishing the UI address ie http://192.168.1.67 or http://mydhcpname as an MQTT value and then HA making UI addresses clickable.
Therefore maybe my feature request is to make correctly formatted URL values clickable
