I just installed my Home Assistant Green (basically just turned it on). Everything seemed to install fine. However, when I go to Settings|System|Storage and then click on Add Network Storage, it does nothing. The Add Network Storage screen does not pop up. This is a fresh install. The only thing that’s been added is HACS and Visual Studio. This works fine on my Home Assistant Yellow which I also have running. Any ideas? Thank you
No. It does nothing. I click on it and no change. Here is my OS that I’m running. It’s exactly the same as my HA Yellow that works fine.
Looks like waiting a day fixed this. LOL. I was about to reinstall everything but decided to just try it again and it worked.
I was about to ask you what the logs had indicated. Somethimes it offers a clue. If I had to guess it would have been a permissions issue - witched may have been updated from a reboot. either way, good to hear past the no burger stage !
