Client error on api app/entrypoint.js request Cannot connect to host 172.30.32.2:80 ssl:None [Host is unreachable]
I suddenly got these errors:
Cannot connect to host aa015h6buqvih86i1.api.met.no:443 ssl:None [Try again]
And now I can’t access my home assistant.
I have duckdns set up and dhcp lease on my router so my hassio always gets the same ip. Everything has been working fine for past 2 months.
My hassio internal ip is 192.168.1…
I read that this could be something to do with DNS. I can’t manually set up dns servers on my router.
I have not set up ssh addon.
Does anyone know what should I do?
Thanks in advance!
Getting the exact same error, also out of the blue…in my case only the HASS.IO tab is gone, the rest of the GUI is visible.
Same here, not sure how to fix this though :frowning:
I also have this now, I’m running Hass.io on version 0.92.2. Anyone found a way around this yet?
Anyone ever figure out what’s causing this? I am getting this now.
