Climate automation (2 windows in 1 room with open/close detection)
Hello friends,
after having tried around for a long time and not finding a perfect solution for me, I have now built a very well working control for my living room heating. I have two windows in my living room and what was most important to me was that no matter which window is opened or closed, the heating is always turned on and off correctly. In addition, the temperature should be given from the thermostat to Home Assistant when the thermostat is changed manually and the values from Home Assistant to the thermostat, all according to the heating mode. I have now also solved everything about 1 mode from the thermostat, since the thermostat is controlled since some Home Assistant versions by the hvac_mode and a preset_mode. After a long time of trying I decided to use only heating and OFF from the thermostat and to define the Eco and heating mode directly in Home Assistant.
I think there are some solutions that are a bit simpler, because it’s all very complex and there’s no holiday mode. This is not so important to me because I switch the heating on and off manually when I come home from work and go to bed. More important to me was that the heating goes off when I open one or both windows.
Logic:
If one of the two windows is opened, it is checked whether the heating mode is set to Eco or Heating, if this is the case, the heating is switched off and the previous heating mode is written into a template. If one window is now closed and the other is still open, nothing happens. Only when both windows are closed will the system check whether the heating was previously in Eco or heating mode and then set it to the previous mode.
With the Xiaomi switch I can manually choose between the heating mode Eco and Heating. So when I go to bed I press the button and the heating goes into Eco mode. When I come home and press the switch, it goes on. Both, however, only if it was previously in either heating or Eco mode.
Devices:
1x Xiaomi Wireless Switch (for manual switching between eco and heating mode)
2x window sensors
1x Eurotronic Spirit Z-Wave Plus Thermostat
Home Assistant Objects:
2 sliders for the temperature setting of eco and heating mode
1 input selector for the thermostat modes (Off, Eco, Heating)
1 template input selector for the previous thermostat modes with window open
Setting options:
Off, Eco, Heating
Temperature for Eco Mode
Temperature for heating mode
configuration.yaml
input_number:
  slider_wzheat:
    min: 8
    max: 28
    step: 0.5
    unit_of_measurement: '°C'
  slider_wzheateco:
    min: 8
    max: 28
    step: 0.5
input_select:
  wzheat_preset:
    options:
      - Aus
      - Eco
      - Heizen
    icon: mdi:radiator
  wzheat_preset_template:
    options:
      - Aus
      - Eco
      - Heizen
sensors.yaml
######  Wohnzimmer Thermostat Sensor ###############################
    wz_thermostat_value:
      value_template: "{{ states.climate.eurotronic_eur_spiritz_wall_radiator_thermostat_heat.attributes.temperature }}"
    wz_thermostat_furnacevalue:
      value_template: "{{ states.climate.eurotronic_eur_spiritz_wall_radiator_thermostat_furnace.attributes.temperature }}"
automations.yaml
### Heizung ####################################################################
######  Ändere Werte bei Input Selector  ###########################
- alias: WZ Heizung AUS
    - platform: state
      entity_id: input_select.wzheat_preset
      to: 'Aus'
    - service: climate.set_hvac_mode
        entity_id: climate.eurotronic_eur_spiritz_wall_radiator_thermostat_heat
        hvac_mode: 'off'
- alias: WZ Heizung ECO
    - platform: state
      to: 'Eco'
        hvac_mode: heat
    - service: climate.set_temperature
      data_template:
        temperature: '{{ states.input_number.slider_wzheateco.state | float }}'
- alias: WZ Heizung AN
    - platform: state
      to: 'Heizen'
        hvac_mode: heat
      data_template:
        temperature: '{{ states.input_number.slider_wzheat.state | float }}'
######  Ändere Werte bei Slider Änderungen #########################
- alias: Slider Set Heat Eco
  hide_entity: true
  initial_state: true
    platform: state
    entity_id: input_number.slider_wzheateco
  condition:
    - condition: state
      state: 'Eco'
      data_template:
        temperature: "{{ states.input_number.slider_wzheateco.state | float }}"
  hide_entity: true
  initial_state: true
    platform: state
  condition:
    - condition: state
      state: 'Heizen'
      data_template:
        temperature: "{{ states.input_number.slider_wzheat.state | float }}"
######  Slider Wert bei manueller Änderung am Thermostat  ##########
- alias: Sync WZ Thermostat Value Heat
    platform: state
    entity_id: sensor.wz_thermostat_value
  condition:
    - condition: state
      state: 'Heizen'
    service: input_number.set_value
    data_template:
      value: "{{ trigger.to_state.state | float }}"
- alias: Sync WZ Thermostat Value Eco
    platform: state
  condition:
    - condition: state
      state: 'Eco'
    data_template:
######  Heizmodus bei Xiaomi Switch Button Press  ##################
- alias: Heizung Wohnzimmer Switch AN
    platform: event
    event_type: xiaomi_aqara.click
    event_data:
      entity_id: binary_sensor.switch_158d00020fec64
      click_type: long_click_press
  condition:
    - condition: state
      state: 'Eco'
        hvac_mode: heat
      data_template:
    - service: input_select.select_option
      data_template:
        option: 'Heizen'
- alias: Heizung Wohnzimmer Switch ECOMODE
    platform: event
    event_data:
  condition:
    - condition: state
      state: 'Heizen'
        hvac_mode: heat
      data_template:
      data_template:
        option: 'Eco'
######  Heizmodus bei Fenster offen  ###############################
- alias: WZ Heizung AUS FenstAUF1
    - platform: state
      entity_id: binary_sensor.door_window_sensor_158d00016cce4b
      to: 'on'
  condition:
    condition: and
    conditions:
    - condition: state
      entity_id: binary_sensor.door_window_sensor_158d0001a99e12
      state: 'off'
    - condition: or
      conditions:
        - condition: state
          state: 'Heizen'
        - condition: state
          state: 'Eco'
      data_template:
        entity_id: input_select.wzheat_preset_template
        option: "{{ states('input_select.wzheat_preset') }}"
      data_template:
        option: 'Aus'
- alias: WZ Heizung AUS FenstAUF2
    - platform: state
      to: 'on'
  condition:
    condition: and
    conditions:
    - condition: state
      state: 'off'
    - condition: or
      conditions:
        - condition: state
          state: 'Heizen'
        - condition: state
          state: 'Eco'
      data_template:
      data_template:
        option: 'Aus'
- alias: Wohnzimmer Heizung EIN bei alle Fenster ZU
    - platform: state
      entity_id: binary_sensor.door_window_sensor_158d00016cce4b, binary_sensor.door_window_sensor_158d0001a99e12
      to: "off"
  condition:
    condition: and
    conditions:
      - condition: state
        entity_id: 'binary_sensor.door_window_sensor_158d00016cce4b'
        state: 'off'
      - condition: state
        entity_id: 'binary_sensor.door_window_sensor_158d0001a99e12'
        state: 'off'
      - condition: or
        conditions:
          - condition: state
            state: 'Heizen'
          - condition: state
            state: 'Eco'
      data_template:
        option: "{{ states('input_select.wzheat_preset_template') }}"
Lovelace UI card
cards:
  - entities:
      - entity: input_select.wzheat_preset
      - entity: input_number.slider_wzheateco
        icon: 'mdi:gauge-low'
        icon: 'mdi:gauge-full'
    show_header_toggle: false
    title: Heizung
    type: entities
  - cards:
      - entity: sensor.wz_thermostat_furnacevalue
        max: 28
        min: 8
        severity:
          green: 22
          red: 18
          yellow: 20
        theme: default
        type: gauge
        unit: °C
      - entity: sensor.wz_thermostat_value
        max: 28
        min: 8
        theme: default
        type: gauge
        unit: °C
    type: horizontal-stack
type: vertical-stack
Anmerkung%202019-10-24%20194615
Anmerkung%202019-10-24%20195215
It all works very well, but I would be very happy about suggestions and tips. :slightly_smiling_face:
Have a look at Schedy https://hass-apps.readthedocs.io/en/latest/apps/schedy/index.html
Ive just started using it with hassio and it works well. It will also do window detection https://hass-apps.readthedocs.io/en/latest/apps/schedy/tips-and-tricks/open-window-detection.html
I’ve seen Schedy before and it looks pretty damn good, but as long as I only have a thermostat in use and the heating is switched on and off manually anyway, Schedy was a little too much for me.
In the long run I will definitely install Schedy as well, as soon as I have equipped all rooms with thermostats.
Thanks to you anyway denver. :slightly_smiling_face:
Hi, i am just curious how you managed to control eurotronics TRV’s with standard HA setup? I have found too many errors in discovery logic’s, also z wave library is of stone age… truly i am very new to HA, just sniffing around for couple months and still don’t know do i like it or not :slight_smile:
