Hi Guys,
This is the first time I’m trying to setup an automation and im struggeling to get it to work correctly, I have made a datetime input and a boolean input.
What im trying to acheive is to turn my AC unit off at a set time if Ive activated that funtion
here is my error:
2022-07-09 07:28:51 ERROR (MainThread) [homeassistant.config] Invalid config for [automation]: [automation air_conditioning_control] is an invalid option for [automation]. Check: automation->automation air_conditioning_control. (See /config/configuration.yaml, line 8).
here is my code:
/config/automations.yaml
# Controlling my AC unit
automation air_conditioning_control:
# When it reaches a set time turn the AC on and activate switch on
- alias: "Turn the AC on"
- platform: time
at: input_datetime.ac_turn_on
condition:
- condition: state
entity_id: input_boolean.ac_turn_on_activate
state: "on"
- service: climate.turn_on
entity_id: climate.daikin_ac
input_datetime:
ac_turn_on:
name: AC on time
has_date: false
has_time: true
ac_turn_off:
name: AC off time
has_date: false
has_time: true
input_boolean:
ac_turn_on_activate:
name: Turn AC on at this time
initial: false
ac_turn_off_activate:
name: Turn AC off at this time
initial: false
Thanks for your help.
