I have this automations section inside of a package.
automation:
- alias: Set Thermostat Mode Off
platform: template
value_template: "{% if is_state('input_select.thermostat_mode', 'off') %}true{% endif %}"
service: switch.turn_Off
entity_id: switch.remotec_zfm80_switch
- alias: Set Thermostat Mode On
platform: template
value_template: "{% if not is_state('input_select.thermostat_mode', 'off') %}true{% endif %}"
service: switch.turn_on
- platform: state
entity_id: input_select.thermostat_mode
- service: climate.set_operation_mode
entity_id: climate.['2gig_technologies_ct101_thermostat_iris_cooling_1']
operation_mode: "{{ trigger.to_state.state }}"
The set mode on/off works. My next attempt was to set the mode of the actual device. climate.[‘2gig_technologies_ct101_thermostat_iris_cooling_1’].
Does anyone see my syntax error.
You’ll want data_template: rather than data: in that last action block. And that entity_id doesn’t look right to me. You probably want just: climate.2gig_technologies_ct101_thermostat_iris_cooling_1. Look for the entity in your states dev tool.
The reason why I did that was when I was templating the other day since it started with a number 2gig, I had to.
Not sure how many issues, fixed the one you mention, I changed the order of entity_id and data. Then I hardcoded to data and operation_mode: Auto and it worked. Then switched to data_template, still no joy. So I hardcoded the template to {{ ‘Off’ }} and it would work. Then I looked back at the input_select part of the package (not shown before) and all my list was lower case. Set the case right and it worked. Thanks for getting me pointed right.
Also, the was a hello world test. Normally you would just use the input zwave provided. But there are other attributes that if I want to change, I have to set. I see there are input_select, input_slider, is there a input_textbox? Back to googling.
