I have the following automation which runs without errors but the temperature setting doesn’t actually work (if I run the set temperature code in the developer tools it works).
If the thermostat was previously set to on then it works but if it was off, it only turns on but doesn’t set the temperature. I suspect that the turn on returns before the thermostat actually goes to on so setting the temperature doesn’t work
alias: Heating nights
description: ''
- platform: time
at: '22:00:00'
condition:
- condition: template
value_template: ' {{ is_state(''input_boolean.vacation_mode'', ''off'') }}'
- choose:
- conditions:
- condition: state
entity_id: binary_sensor.workday_sensor
state: 'off'
sequence:
- wait_for_trigger:
- platform: time
at: '23:59:00'
default: []
- service: climate.turn_on
entity_id: climate.t6_pro_z_wave_programmable_thermostat
- service: climate.set_temperature
temperature: 14
hvac_mode: heat
mode: single
