Is there a way to show all services as per popup
The new popup climate tab is the top image, the bottom image is the dashboard climate tab.
climate:
- platform: climate_template
unique_id: termo_Sauna
modes:
- "off"
- "heat"
- "dry"
min_temp: 40
max_temp: 100
min_humidity: 0
max_humidity: 100
temp_step: 1.0
# sonda temperatura sauna
current_temperature_template: "{{ states('sensor.spa_sonda_temp_sauna') }}"
# sonda umidità sauna
current_humidity_template: "{{ states('number.spa_setpoint_umid_biosauna') }}" #per il momento metto il setpoint dopo metto la sonda di umidità
# setpoit temperatura Sauna
target_temperature_template: "{{states ('number.spa_setpoint_temp_sauna') }}"
# setpoit umidità Sauna
target_humidity_template: "{{states ('number.spa_setpoint_umid_biosauna') }}"
set_temperature:
- service: number.set_value
entity_id: number.spa_setpoint_temp_sauna
value: "{{ temperature }}"
set_humidity:
entity_id: number.spa_setpoint_umid_biosauna
value: "{{ humidity }}"
hvac_action_template: "{{ state('switch.spa_termo_sauna_auto_off' ) }}"
set_hvac_mode:
- service: switch.turn_{{ 'off' if hvac_mode == 'off' else 'on' }}
entity_id: switch.spa_termo_sauna_auto_off
- service: select.select_option
entity_id: select.spa_sell_biosauna_sauna
option: "{{ 'Biosauna' if hvac_mode == 'dry' else 'Sauna' if hvac_mode == 'heat' else 'off' if hvac_mode == 'off'}}"
# - service: switch.turn_{{ 'off' if hvac_mode == 'dry' else 'on' if hvac_mode == 'heat' }}
# entity_id: switch.spa_sel_on_sauna_off_biosauna
