I have automations for when our central heating system should come on.
At any time if temp gets below 15.5 degrees, it overrides and turns on.
Between 5am and 8am if the temp is < 18 degrees, turn on.
After 8am to 10pm if someones wants it, they just turn it on manually. When you want it off, set it off, or back to schedule mode.
At 10 pm, it’;s reset from on, and set back to schedule mode so that if needed at 5am it will come back on.
I’m trying to move to using a climate control (so I get a pretty widget in homekit).
So I’ve grabbed the generic thermostat. and hooked it a fake central heating switch, and the average house temp.
- platform: generic_thermostat
# switch to control to turn heating on/off
heater: input_boolean.test_central_heating
# current temp sensor
target_sensor: sensor.average_house_temp
min_temp: 15.0
max_temp: 21.0
target_temp: 18.0
temp_step: 0.2
ac_mode: false
hot_tolerance: 0.2
cold_tolerance: 0.2
min_cyle_duration:
minutes: 10
keep_alive:
minutes: 30
initial_operation_mode: 'auto'
So I’m looking at node-red for controlling it. I can get the override temps and the morning temperature to work by looking at the time, and if between 5 and 8, set target temp to 19 degrees. Otherwise set target at 15.
But with the config of the climate control, I only get the option in lovelace for off or heat. I was expecting something like on/off and an auto mode.
Probably not. When I started using generic_thermostat, I’d been told to use these 2 platforms.
Almost all settings are in generic_thermostat anyway.
And I’ve just checked and can conform that you don’t need that demo at all, it works without it just fine.
That’s probably why there is no info on that available. HA is evolving rapidly and often the docs do not reflect all changes…
Currently the generic_thermostat climate platform supports ‘heat’, ‘cool’ and ‘off’ operation modes. You can force your generic_thermostat to avoid starting by setting Operation to ‘off’.
The only way I can really get what I want, when a user wants the manually overnight de it, set the target temp to current temp plus sone, so it won’t reach it.
