Hi all,
I’m struggling to control a climate controlled heat pump in Node Red.
I do have the below in configuration.yaml and it works just fine controlling it via Lovelace.
`# Heat pump setting
climate:
- platform: mqtt
temperature_state_topic: “f4cfa2734882/HP/0203”
temperature_command_topic: “f4cfa2734882/HP/SET/0203”
min_temp: 13
max_temp: 26
temp_step: .1
name: “Room temp setting” - platform: mqtt
temperature_state_topic: “f4cfa2734882/HP/2204”
temperature_command_topic: “f4cfa2734882/HP/SET/2204”
min_temp: 0
max_temp: 10
temp_step: .1
name: “Room sensor influence setting” - platform: mqtt
temperature_state_topic: “f4cfa2734882/HP/2205”
temperature_command_topic: “f4cfa2734882/HP/SET/2205”
min_temp: 0
max_temp: 10
temp_step: .1
name: “Heat Curve setting” - platform: mqtt
temperature_state_topic: “f4cfa2734882/HP/0207”
temperature_command_topic: “f4cfa2734882/HP/SET/0207”
min_temp: 0
max_temp: 10
temp_step: .1
name: “Heat parallel setting”`
However i cannot manage to control it via Node Red ( i do have other Node Red automations that works just fine)?
One example (of many) I have tried is the below:
[{“id”:“1c243697.9a3bd9”,“type”:“api-call-service”,“z”:“295ab6f.8709f4a”,“name”:“Paralell Heat setting”,“server”:“f8e3debf.24b33”,“version”:1,“debugenabled”:false,“service_domain”:“climate”,“service”:“set_temperature”,“entityId”:“climate.heat_parallel_setting”,“data”:"{3}",“dataType”:“json”,“mergecontext”:"",“output_location”:“payload”,“output_location_type”:“msg”,“mustacheAltTags”:false,“x”:440,“y”:200,“wires”:[[“22fabe22.0a6f02”]]},{“id”:“f8e3debf.24b33”,“type”:“server”,“name”:“Home Assistant”}]
Any input is welcome
![:slight_smile: :slight_smile:](https://community.home-assistant.io/images/emoji/twitter/slight_smile.png?v=9)
