In my appartment I´ve rooms with two radiators and and therefore also two trvs and I want to control them both at the same time. If someone is changing the set temp. manually on one trv the other trv should set to the same temp. At this time I use the HACS climate_group and for controlling both through HA it works thru automation. But if I change the temp on one trv the temp of the group device is a average from both trvs. Is there any chance to change the behaviour? And if not: I´ve tried to create an automation but I want to use a generic one that fits on different rooms. Let give me an example:
Kinderzimmer:
climate.thermostat_kinderzimmer_links
climate.thermostat_kinderzimmer_rechts
Wohnzimmer:
climate.thermostat_wohnzimmer_links
climate.thermostat_wohnzimmer_rechts
So I think it should be possible to create a value_template as trigger that covers each room and each direction (links or rechts) and will set the temp on each to the other in action.
I hope someone could help me and I described the problem well - if not please dont hestitate to ask me :).
