I have a history card showing the temperature history of my HomematicIP thermostats. Today, I accidently added the climate entity, and noticed that I get to history graphs, showing not only the current, but also the target temperature. I want this
However, the two graphs get very ugly labels, something like “HomematicIP AP Thermostate Current Temperature” and “HomematicIP AP Thermostate Target Temperature”. I’d like to change them into e.g. “Temperature” and “Target”. I see two options to fix this, but don’t know whether they can be realized (at least I don’t know how), and of course there might be other ways…
Option 1: Change the labels of the two graphs which I get from adding the (single) entity (but how?)
Option 2: Add the “Target temperature” attribute as the second graph to my history card (but how to access the climate’s attribute?)
And just in case: I want to control the labels of the 2nd one, and change them into something like “Temperatur” and “Zieltemperatur” (German versions of “temperature” and “target temperature”)…
No need to post vertical-stack at all, all unrelated code is a distraction.
This option is deprecated for about a year.
Assume this entity has some SHORT friendly_name explicitly defined.
Then you will see it in History-graph - if you do not specify this “name” option.
So, “name” option overrides this friendly_name (defined by a user explicitly or defined automatically).
When you place a climate entity in history-graph - you are getting a similar behaviour.
Try to define a “name: xxx”. See what happens.
Thanks for your comments! I was of course aware of the fact that the vertical stack is not relevant here - I decided to still post it as it is to avoid any dangers of messing up by changing the code.
And thanks for letting me know - I didn’t receive any “deprecated” warning (which I get from the coding tools I’m working with on daily basis), so I didn’t realize - will remove these settings.
And again of course ;-), I tried to use the name setting, but it didn’t work (and how could it? It’s one setting, but two labels). Here’s what I get:
