since the last update all my climate entity is not available.
climate.fibaro_system_fgt001_heat_controller_heating
Help please !
Help please !
Do you see any errors in the log (Developer Tools -> Logs)?
I had it also afer the last update.
All the climate entities appeared to be hidden.
Enable solved the problem
Thx but how to enable entities not hidden ?
No in logs there are not error
this controller zwave? if yes are other zwave devices working?
All node work in Zwave just all my climate not work.
Fibaro and Eurotronic the same issue
So I guess you need to check if the climate device is in the zwave network. if not then you need to reconnect it etc…
Go to Configuration -> Entities, click on the entity, there should be a toggle to enable/disable it.
Strange beacause the entity is not hidden.
The
climate.eurotronic_eur_spiritz_wall_radiator_thermostat_heat
not working
but if I take
climate.eurotronic_eur_spiritz_wall_radiator_thermostat_mode
it’s working.
The entities *_head not ok the other yes
You mean like the release notes indicated?
Yes I’m not alone !
You were literally warned about it…I don’t understand how you can just blindly update things without reading the BREAKING CHANGES in the release notes.
It’s simple I make the mistake to not read the release before click update.
And just play with the new notification with the app.
No body is perfect sorry
