Hi folks
I want to have all climate entity with a dynamic target temperature
I tried
target_temp: {{ states ('sensor.fussbodenheizung_soll) | float(0) }}
but it ends in an error
Asside from that I want to show the controller output level.
It is also a sensor value
All these values are from my heater.
I don’t want to control anything. Just show the values in a climatecontroller graphic card
regards
BJ70
tom_l
September 24, 2023, 9:31am
2
Where did you try this and what was the complete error text?
I tried this in configuration.yaml
under climate
Here ist the full entry:
climate:
- platform: generic_thermostat
heater: binary_sensor.heizungsbrenner
target_sensor: sensor.fussbodenheizung_istwert
target_temp: {{ states ('sensor.fussbodenheizung_sollwert) | float(0) }}
min_temp: 20
max_temp: 45
and here ist the errortext
Error loading /config/configuration.yaml: invalid key: “{“states(‘sensor.fussbodenheizung_sollwert’) | float(0)”: None}” in “/config/configuration.yaml”, line 464, column 0
tom_l
September 24, 2023, 9:53am
4
That option does not accept templates. Unless an option specifically lists templates in its documentation, then it does not.
You will have to automate this.
Trigger on any state change of your sensor and set the temperature in the action.
How can I do this?
alias: Sollwertupdate
description: ""
- platform: state
entity_id:
- sensor.fussbodenheizung_sollwert
condition: []
- service: climate.set_temperature
value: sensor.fussbodenheizung_sollwert
entity_id: climate.heatronic_fbh
mode: single
What must bei in data
Dujith
(Charles Evers)
September 24, 2023, 12:03pm
6
Arent you missing a '
target_temp: {{ states('sensor.fussbodenheizung_soll') | float(0) }}
You could create a template sensor with that tho if its not supported in climate
Just listen to tom_I
tom_l
September 24, 2023, 12:16pm
7
value: "{{ states('sensor.fussbodenheizung_sollwert') }}"
We may have to format this data if say your climate temperature only accepts integers and your sensor contains a value with decimal parts.
Also to prevent triggering on unknown states change your trigger to:
- platform: state
entity_id:
not_to:
- unknown
- unavailable
tom_l
September 24, 2023, 12:21pm
8
Doesn’t matter if the template is correct or not. That option still won’t accept a template.
Also how does creating a template sensor help with adjusting the temperature?
The automation now works.
…but IT doesn’t update the value in the climate entity
Now it works.
I have to use temperature
instead of value
Dujith
(Charles Evers)
September 24, 2023, 1:10pm
11
I think i’m having a litlle brain fart. After rereading this on the computer instead of phone i see my reply does not make sense apart from the missing ’ which doesnt matter in the end. Blame it on waking up so soon for F1
