Climate esphome
is working
binary_sensor:
  - platform: gpio
    pin: D5
    name: "Kombi Up Button"
    internal: true
    on_press:
      - logger.log: "######### up button"
      - while:
          condition:
            and:
              - binary_sensor.is_on: kombi_up_button
              - lambda: 'return id(kombi_termostat).target_temperature < 30.0;'
          then:
          - climate.control:
              mode: HEAT
              target_temperature: !lambda |-
                return id(kombi_termostat).target_temperature + 0.5;
          - logger.log:
              format: "######### set target temp %.1f"
              args: ["id(kombi_termostat).target_temperature"]
          - delay: 700ms
    on_multi_click:
    # mode off by pressing two keys
    - timing:
      - ON for at least 0.7s
      then:
      - if:
          condition:
          - binary_sensor.is_on: kombi_down_button
          - lambda: 'return id(kombi_termostat).mode;'
          then:
            climate.control:
              mode: "OFF"
  - platform: gpio
    pin: D6
    name: "Kombi Down Button"
    internal: true
    on_press:
      - logger.log: "######### down button"
      - while:
          condition:
            and:
          then:
          - climate.control:
              mode: HEAT
          - logger.log:
          - delay: 700ms
climate:
  - platform: thermostat
    sensor: temp # sensor edit!
    name: "Kombi Termostat"
    default_target_temperature_low: 23 °C
    visual:
      min_temperature: 18 °C
      max_temperature: 30 °C
      temperature_step: 0.5 °C
    heat_action:
      - switch.turn_on: kombi_relay
    idle_action:
      - switch.turn_off: kombi_relay
  - platform: sht3xd
    temperature:
      name: "Kombi Termostat - Temperature"
    humidity:
      name: "Kombi Termostat - Humidity"
    address: 0x44
  - platform: homeassistant
    entity_id: sensor.sicaklik
    internal: true
    on_value:
      then:
        - logger.log: "######### temp_ha to temp"
        - lambda: 'id(temp).publish_state(id(temp_ha).state);'
    entity_id: sensor.nem
    internal: true
    internal: true
    lambda: |-
      return id(temp_ha).has_state() ? id(temp_ha).state: id(temp_local).state;
