LOAD AN EXAMPLE ESPHOME CLIMATE BANG BANG BUT I RECEIVE ERROR. I DON’T UNDERSTAND WHAT TO DO?
Misspelled heater as heatery (last line). Suggest you use esphome category next time and more details like error message, etc.
Fixed.
I changed the category … but you did not respond well to my request.
i have experience on arduino c ++ files and souliss smathome.
the esphome guide is unclear on how to make projects, or how to manage programming. it is a confusing guide that must surely be revisited. whoever is preparing for a new reality cannot take knowledge for granted
Please have a read of this: How to help us help you - or How to ask a good question
The good news is you can help fix it.
then I have an HA on active raspberry with integrated esphome
I created a simple on off switch
now I wanted to create a thermostat and I edited the esphome file to load this example:
but i get error as shown in the image above.
Fix the spelling in your last line. See if that fixes it.
PS you were told this in the second post.
I configured a climate bang bang on esphome with nextion display, and I can turn on and off via the touch button.
then in lambda I have a variable that increases and decreases through 2 other touch keys on nextion to set the setpoint from local without use of home assistant, however I can’t import the values of the variable to home assistant.
can someone help me?
this is what I did to turn the climate on and off:
- platform: nextion
page_id: 0
component_id: 3
name: "Nextion beep button"
on_press:
then:
lambda: |-
if (id(nextion_beep_button).state) {
if (id(bang_bang_climate).mode){
auto call = id(bang_bang_climate).make_call();
call.set_mode("OFF");
call.perform();
} else {
call.set_mode("AUTO");
call.perform();
Please post your code properly.
#TERMOSTATO BANG BANG CON DISPLAY NEXTION
uart:
rx_pin: GPIO13 #D7
tx_pin: GPIO2 #D4
baud_rate: 9600
display:
- platform: nextion
update_interval: 3s
lambda: |-
// Do not wait for ACK - it slows down the process, and has no use
it.set_wait_for_ack(false);
if (id(Heating_D3).state){
it.set_component_text("t0", "acceso");
}else{
it.set_component_text("t0", "spento");
dallas:
- pin: GPIO5
#0x0E041623899DFF28
binary_sensor:
- platform: status
name: "ESP Smartthermostat Status"
- platform: nextion
page_id: 0
component_id: 3
on_press:
then:
lambda: |-
call.perform();
} else {
call.perform();
- platform: nextion
page_id: 0
component_id: 4
name: "Nextion beep button UP"
# In an automation
on_press:
then:
- lambda: |-
if (id(nextion_beep_button_UP).state) {
id(bang_bang_climate).target_temperature_high += 0.5;
} // not function
- platform: dallas
address: 0x0E041623899DFF28
switch:
- platform: gpio
pin: GPIO15
climate:
- platform: bang_bang
sensor: temp_dallas_1
visual:
min_temperature: 12 °C
max_temperature: 25 °C
temperature_step: 0.1 °C
default_target_temperature_low: 12 °C
default_target_temperature_high: 22 °C
heat_action:
- switch.turn_on: Heating_D3
idle_action:
- switch.turn_off: Heating_D3
Maybe you are new here. Edit your post and place 3 backticks before and after your code, the backticks go in a line of their own. See point 11 here How to help us help you - or How to ask a good question
EDIT please don’t ignore that link like you did when @tom_l posted it earlier in the thread!
correct…
Sorry but I’m new
Why don’t you use the climate control action? https://esphome.io/components/climate/index.html#climate-control-action
I tried but that control I don’t know how to place it … it always gives me error … I don’t know …
show me an example if you can …
thanks
We can’t tell you what you’ve done wrong if you don’t show us your code and whatever error your code throws up. Anyway actions are documented https://esphome.io/guides/automations.html#config-action
An example please @nickrout
What error are yiu seeing.
I’m not getting any errors, I haven’t even tried. I don’t understand if the control.climate should be inserted under an action of the type on … @nickrout
Make up your mind!
HI!
I see what I want. But I am only At the very beginning of the journey. Tell me, did you succeed? Can you share the code?
