Lynny
(Lynn Bayer)
November 17, 2022, 1:33pm
1
Hey,
i need help with the generic_thermostat.
I have a circulationpump which can be turns on with a switch. So i set up this in the climate section.
My understanding is that the thermostat turns on the switch when the temperature is to low and turns it of when it reaches the target temperature.
In the UI i used the Standard and after that the Better Thermostat. But the state is idle and the pump isn’t turned on.
so what do i do wrong or is it not possible to control switches with that.
Thanks a lot in advanced
Lynn
Dujith
(Charles Evers)
November 17, 2022, 1:45pm
2
When u post the config do so in code tags and not a screenshot, it helps looking for format errors and such. Anyway, in this case it looks like the sensor.kuche_temperatur is not giving a value.
If you look at the sensor in the developer tools, what does it say?
The thermostat should report actual temp and not be empty:
Dujith
(Charles Evers)
November 17, 2022, 1:58pm
4
Code tage are done with the preformatted text button </> press it (or Ctrl-e) and it will show up
Post your config in it.
Lynny
(Lynn Bayer)
November 17, 2022, 2:03pm
5
- platform: generic_thermostat
name: Küche Thermostat
heater: switch.pumpe_heizung
target_sensor: sensor.bad
min_temp: 15
max_temp: 25
target_temp: 19
hot_tolerance: 1
initial_hvac_mode: "off"
away_temp: 16
precision: 0.1
ac_mode: false
cold_tolerance: 1
Lynny
(Lynn Bayer)
November 17, 2022, 2:06pm
7
As you see i changed the sensor to sensor.bad
Now it worked. Hm.
So i changed it back to the sensor.kuche_temperatur and now it works also.
Thanks a lot
