Climate hvac mode is missing window state open/close - IDLE not available in hvac_action:
i am missing an option to set my TRV to window is open/close state.
My Shelly Valve Hardware: gen1 (SHTRV-01) has an option with an api command
for example curl http://deviceIP/window?state=close this sets the TRV to close the valve if the windows is open and return back to the mode before when the state goes to close.
i just see, if i set the TRV to mode window open the attribute goes to
hvac_action: idle
and the temperature is set
temperature: 8
the valve position goes to 0
but i can’t set this in an automation because there is no option IDLE
